Results 1 to 12 of 12
Thread: Timing chain for the honda accord?
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    After reading the current posts about the dangers of broken timing belts, I find myself wondering if there's an after market mod available to switch it to a timing chain. (on the 87 lx/dx) I figure it's probably time to change my own considering everything else that has broken on the car since I bought it a year ago. Haven't found any mention of such online or in the forums here. Anyone run across this?
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    The pulleys are designed to only accept a belt. To run a chain, different pulleys would need to be used. It's easy to change, just make sure you do it at the recommended intervals.
    10/Honda/Ridgeline
    NJ
    its not easy to change from a belt to a chain set up. U have to be careful about the rotation per minute that is exact to the crank to cam ratio. Let alone u have to change the tensioner, the crank itself and cam gear to accept a chain belt. they are usually dual roller chains. Besides, they got racing belts such as toda and what not that can be adapted to our cars if possible. Some even try nissan and toyota belts. As long as the teeth count and hence belt length are exact, u got no problems.
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    also in order to do a timing chain (which is a shit load louder than a timing belt also, why auto manufactures switched in the first place) you would have to find some way to seal the engine front end cover so it could have oil in it because the timing chain needs to be immersed in engine oil, also you would need to add some ports or something so that oil could be sprayed on it, so custom oil nozzles and a custom piece of metal to go where the timing belt cover goes in addition to new sprockets on everything, i woudl say all that in the end would be more likely to fail than just keepin the timing belt on and checking it once in awhile
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    Quote Originally Posted by johnwc723
    Good points, though to be honest I figured they switched because they were just cheap.
    Vanilla Sky's Avatar
    1999 Penalty Box
    eh, the nissan 3.5 engines use a chain... i believe the 5.* in the titan/armada also uses a chain... i believe my dad's hardbody has a chain... just my $0.02
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    hmm even timing chains have problems.
    like on the quad 4's.
    they have to be replaced often, do to tensioner problems.
    i say just get a stronger belt.
    LX User rideredorgohome's Avatar
    Feb 2003
    1988 Honda Accord "S" model, Carbureted
    London,Ontario
    Quote Originally Posted by iron
    I take it you have never seen what happens when a CHAIN breaks!!! Cracked cases that's what!!!!
    "There are good cars out there, and then there's Honda. Ride Red or Go Home..."
    Current Mods:
    K&N Air Filter
    Blue Anodized Oil Filler Cap
    Chrome Shifter Knob
    PIAA Wipers
    Dynomax Performance Cat
    Dynomax Muffler
    k-roy's Avatar
    87 LX
    If you want a timing chain you could always swap in a F22C
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by k-roy
    or a K series
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    Quote Originally Posted by rideredorgohome
    You are correct, I've seen a few friends with broken belts, but I've never seen a chain break, leading me to believe that chains are hardier than belts. Of course coming from a back ground of wrenching older ford engines I expect that I've got quite a bit to learn about my 4 cylinder. The whole transaxle concept still feels alien to me at this point.
    10/Honda/Ridgeline
    NJ
    talkin about transaxles, take a look at the engines G20 and the second gen C27 (came in 2nd gen legend). THey are both honda engines, weird layout for a FWD. so yeah, now thats friggin alien hehehe.
  1. 88 Accord Timing Adjustment
    By Xaisk in forum Carburetor Tech
    Last Post: 03-03-2010, 10:52 AM
  2. 87 Honda Accord Ignition timing Problem
    By momin in forum 3geez Accords
    Last Post: 04-20-2006, 08:48 AM
  3. engine has sound of chain
    By toaster13 in forum 3geez Accords
    Last Post: 04-05-2004, 12:33 PM
