Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: pics of my custom front and rear strut bar as i told ya
    nice work. so is it posible to get biffrent types of bars instead of that one?
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Funky, can;'t believe i never saw this thread before... I might have to give this a try... so, are the bars the right length? and what brand of bars did you use?
    LXi User L3G10N's Avatar
    Princeville, Quebec
    Cheesburger: Yes you can get different type of bar to do this but for the front, Be sure that the strut piece are molded in two parts just like mine or you won't be able to split 'em in two parts to relocate the upper parts on the bottom plate.
    Hash_Man_Se_i: Yes the length are exactly the same between 3rd gen and 4th gen Accord. And i used a Vibrant Front Strut Bar and a Ractive rear one. For Carotman's rear strut, it's a no name rear 4th gen Accord brand.
    My 86 custom build thread
    Princeville, Quebec
    My next try will be the lower tie bar. But i don'T know wich brand are available for this part for accord 90-93 and for a reasonable price. I mean, if i have to do some test, a DC lower Tie Bar will be a lot expensive for this.
    So Cal, Orange Co.
    just wanted everyone to know im going to make my own this same way, im in metal shop right now, woo hoo!
    Ill get some pics of it when its installed
    Kevin
    Princeville, Quebec
    I've did my test about the lower Tie Bar. You can buy any 90-97 lower tie bar. It will fit your 3geez without any modification.
    My test was did with a Megan Racing accord 94-97 on my Se-I cross-member.
    Feb 2003
    1950 Plymouth daily driver, 1967 Riviera, 1951 Buick Roadmaster with a 455
    Spokane WA
    Allright!!! this is sweet! i have access to a welder and i know how to use it. Thanks to you guys for starting this and showin how easy it is! I never woulda guessed
  8. #33
    Princeville, Quebec
    just to tell you that my front strut bar are done!!!! and it fit perfectly
  9. #34
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    Re: pics of my custom front and rear strut bar as i told ya
    this is kinda an old thread but im bringing back cause i bought the front and rear uppers for the 90-97 accord, cut the bracktes and blah blah did everything like is shown in the pictures and the back ones one good, definaly feel a difference but the front one is to short lengh wise and hight wise so just tyring to see if this guy actually ever posted any pictrues of the front one on the car cause mine doesnt fit and im kickin myself in the pants cause i should have checked the length and eveything before i cut and re-welded the brakcets cause i got some buddys with thr 4th gen's so i coulda re-sold it to them but not know, im thinking im might just cut the bar shorter and make a rear lower, so yea anybody have any pics of the 90-97 accord front upper strut bar actually on our cars, thanks
  10. #35
    Jun 2001
    Boston MA
    maybe ill try this
    S.Q.U.A.D. Engineering
    www.squadengineering.com
  11. #36
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    I ran into the same problem with mine, but I'm sending it back to get a different bar, the rear one I got was too short, so I have the brakets on my car but no bar.....I'm going to get some chomoly tubing and use that instead....and here I thought I was the only one........
  12. #37
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Quote Originally Posted by mykwikcoupe
    welding is simple. Just take an extension cord and trim the positive lead so theres a few inches of copper showing and make sure you have a Zinsco house panel, rubber mount to be grounded on and dont get caught in the circiut. Im an electricin trust me on this one
    For those of you dumb enough to try this DONT. Its a Joke at 2 am. HA HA
    lol i was actually thinking "sweet now i can weld " but then i read the rest
    -Gio
    My E85 Turbo Build
    5280FEST
  13. #38
    Princeville, Quebec
    the rear one was perfect, but hte front was a bit short. But not that much. I was able to put 'em on the car. For sure, Best thing is to get some longer bolt or do some larger topshock plate. I am working on the second option now. I'll post some pic of the new one soon. I don't have any pics of the bar on my car too since my car is in the body shop see there .
    If guys want to show me which bar you all have, i can do the front plate for everyone for the price of the metal i'll need to buy + ship. It depends on wich bar you have.
    Just as the rear lower too, it's a tight fit too. I have removed 3mm at each side of the bar cause it was too large.
  14. #39
    1987 Ex-i 89 SE-i
    do have any pictrues of the 90-97 accord front upper strut bar on your car, iv got an idea of how to make it work but i just wanna see how you did it , it might possible give me some different ideas and also help other members trying this, il also try my way and try to post some pics to see if i can help anybody
  15. #40
    A Mile High.
    which others will work on our cars?? just the 90-97 accords or what??
    -Gio
    My E85 Turbo Build
    5280FEST
  16. #41
    Calgary, AB, Canada
    pretty much anything with the right length would work, you just have to customize the mounting plates... Me and a friend are going to try this soon as he just bought himself I nice shiney new miller. I'm pretty stoked.
  17. #42
    1987 Ex-i 89 SE-i
    just on a side note, for the rear upper strut bar you dont have to heat and bend it, you can cut and re-weld just like the front plates, i was gonna try bending but when i went to use the oxy torch i ran outta acetelene (spelling?)so i just cut it and re-welded it, works just fine, figured id let some of you guys know just incase you didnt have a source of heat
  18. #43
    Princeville, Quebec
    b8er tnx for the precision!!
  19. #44
    1989 Accord LXI Coupe
    Santa Barbara, CA
    are you making any bars, or do you have any that are for sale?? that are already modded to fit the 3g???
    anyone in that case, (cause shipping would be a biatch {i soppose} from quebec)
    V12 Supercharged Toyota Accord
  20. #45
    Princeville, Quebec
    I just have my set did for myself. But i can make u a set too if you want. Shipping won't be that much i think.
  21. #46
    A Mile High.
    how much would it be for one for the rear
    -Gio
    My E85 Turbo Build
    5280FEST
  22. #47
    Princeville, Quebec
    well, i think what should be best is that you buy one from ebay and make it sent to my home. I'll mod it and send it back to you after. What do you think of that?
  23. #48
    Santa Barbara, CA
    how much to ship to 92662???
    if you want, i can give you a deposit, i want a front and rear uppers...... let me know.
    let me know how much, and how long i would have to wait.... thanks!
  1. New custom front strut brace....
    By Jasonf860 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-13-2013, 08:33 AM
  2. Front and rear strut bars....
    By ROniel in forum Wanted
    Last Post: 06-01-2011, 10:20 AM
  3. Custom Strut Braces for the Rear..
    By Tomisimo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-06-2009, 06:44 AM
  4. I have found a front or rear strut bar for $50 shipped
    By neoblue89lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-20-2004, 08:41 PM
  5. Front & Rear Strut Bars?
    By Fascarz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-01-2002, 08:29 PM
