i know a20a1 played around with this idea.has anyone tryed to mod the accelerator pump to put out more fuel.i also know you can use a stronger return spring to help get the fuel sucked into the diaphragm faster. can the ports be drilled larger? or are there any other options for moding the keihn carb accelerator pump? i dont have the deniro for a weber carb so ide like to see if i can get this thing to run the best it can for now. any new stock carb mod ideas lurking around out there? im a glutton for cheap mods![]()
