Will a carb distributor work on a efi lxi?? I need one but cant find an lxi/efi one!!
Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
the distributers are not intercahngeable between EFI anc carbed. if u have a lix you ahve to get a efi dist witehr form a lxi, sei or a 2nd gen lude si. if your car is carbed you need a 3rd gen accord carbed dist.
-1986 Honda Prelude DX:
pacesetter cat back w/Magnaflow muffler
lightspeed header
ngk iridium plugs
Pacesetter short shifter
94' integra coilovers
k&n oil filter
On ebay i found a OBD 0 to OBD 1 Distributor Adapter!! It says used for civic or integra. But also says that it will allow you to plug your OBD0 harness into your OBD1 distributor. So if i get a 90 accord distributor this will make it work??? Info and feedback needed!! My car is still not running right!!!!
No it will not work. Get one off a LXi and you will be strait.
ok thanks!!
Why is my distributor ticking?? I am still having problems w/ my car running. At an idle i can hear a ticking noise from the distributor. The car also sounds/runs like its only running on 3 cylinders. If the distributor was messed up could this cause the car to run like that??
