Hi Again,
I previously posted regarding a suddenly smokey motor (thanks to all those who gave advice)... and the end result is I am fitting a second hand engine... two mechanics recommended this as the best course of action after having a look at the car. I am planning to replace crank and cam seals, timing belt, water pump and all those small coolant hoses around the inlet manifold before I fit the motor.
Any other suggestions as to what should be done to the replacement motor before I fit it to the car????
Thanks
John
