Results 1 to 12 of 12
Thread: valve clearance specs?
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    k, i'm getting the stage one tri-flow Colt cam, and i was wondering if the valve clearances are the same as stock or if they're different. if they're different, i need to know them. i'm installing the new cam thursday, and i'm trying to get everything i need tomorrow (or today.., it's after midnight...). so, anyways, anybody know this?
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You will get a cam card with the clearances... but you can start out with a larger stock gap and then slowly tighten the gap after some use. The gaps should be listed on the sticker under the hood.
    maka_RTH's Avatar
    Nov 2001
    Orem, Utah
    i'm getting the cam used from another member..., and he said he couldn't remember if he got a cam card or not with it.., so i was just wondering if anybody else that has got this grind has it handy or something.
    cam specs:
    intake 260, 384 lift
    intake 270, 384 lift
    exhaust 274, 402 lift
    Greg
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    i bought a mild performance (triflow) camshaft from colt, you need to readjust the valves to stock clearances
    .05 - .07 for intake
    .10 - .12 for exhaust
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    He meant 0.005-0.007 intake and 0.010 - 0.012 exhaust
    Mike
    Apr 2004
    89 Lx-i
    Berkeley, CA
    yeah ... who measures things in thousandths of inches, anyways?
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    honda does
    not that u need the info, a delta cam need .060 intake and .080 exhuast.
    k-roy's Avatar
    87 LX
    Quote Originally Posted by mr eff
    Every single automobile manufacturer on this planet.
    May 2003
    05 Legacy GT 87/accord/lx (rip)
    boston
    Um... I'm about to put in a new cam... Geof from Colt Cams wrote: .006 intake, .007 exhaust (cold). Is the exhaust valve spec too low... I mean could he have made a mistake wirting .007?
    A20A1's Avatar
    Sep 2001
    not really, it's just safer to have a larger gap cause that makes sure the exhaust valve has a chance to transfer heat properly to the head.
    You'll get more power from the cam with the smaller gap though.
    '85 lude
    houston
    actually honda doeasnt.
    they use mm
    anyway, always use stock spec. the cam does not change that. valve clearances are for expansion of the valves as the motor heats up. if its to loose they will make extra noise and lower performance. if they are too tight it can burn a valve.
    May 2003
    boston
    Soo..... I should use stock gap? Hmm... I'll set it at .006 in and .010 ex and see how it sounds...
  1. Need help adjusting my valve clearance
    By Hazwan in forum 1geez Tech & Performance
    Last Post: 05-07-2009, 08:25 PM
  2. Valve spring specs.
    By rob_himself in forum Performance
    Last Post: 06-05-2008, 12:48 PM
  3. caliper clearance
    By rustlude87 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-21-2006, 07:43 AM
  4. [Engine & Transmission] Adjusting Valve Lash and Clearance
    By Knowledge Base Admin in forum How To
    Last Post: 11-09-2004, 08:39 PM
  5. Valve clearance shaith
    By skull1441 in forum Performance
    Last Post: 06-26-2004, 06:02 PM
