Results 1 to 7 of 7
Thread: Popping out of gear
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    Popping out of gear
    Hey guys got any ideas on this one? Hopefully not ANOTHER tranny rebuild. I just finished working on my 87 lx 5sp and took it out for a test drive. It still has trouble idling, so I'll be rebuilding the carb after all, but when at highway speed tonight (60 to 70) it started kicking out of 5th gear. It'll stay in 5th at 45 mp but get it up to 60 and pop out it comes. I just had this thing rebuilt like a thousand miles ago. No strange noises like the time the bearing blew, any ideas?
    shepherd79's Avatar
    Falling Waters, WV USA
    it something inside the tranny. take it to a shop that did and tell them to fix it if it still under warranty.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    It may be low on oil. You may want to check the level. Other people have reported a similar problem right before the fifth gear went south. The Accord transmissions are very sensitive to low lubricant levels. Hope this helps you.
    3axap.
    k-roy's Avatar
    87 LX
    I changed the tranny oil and did not put enough back in and it kept popping out of fifth gear. 5th is the highest gear so if the level is low it slips out. Try topping off the fluid with the car jacked up on the passenger side so you can get the most amount in there possibl. Do it quick before the gear gets bunt out.
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    Thanks guys, I'll be checking the level in the am. No warranty on the tranny it was a junkyard rebuild Hell haven't managed to get a thousand miles on the tranny since it was rebuilt almost a year ago, something else always breaks and I sideline the car. Before long I should have a brand new car at this rate!
    87accordlxi's Avatar
    Oct 2000
    Yep, it's the oil. When I first got my car, it kept popping out of 5th gear. If I wasn't quick enough after it popped out, the cruise control would wring out the engine.
    - Joe
    Jul 2004
    87 Honda Accord LX
    SW Virginia
    Well it was a little low, bad news is more oil didn't cure it. My mechanic thinks it's a synchronizer. I think that this time I'll rebuild the thing myself. Dreading that though. Maybe I'll just find another tranny and swap it in. This car is dragging me kicking screaming into ares of auto mechanics I'd always wanted to avoid!
  1. 5th Gear Keeps Popping out...need help
    By integrapwnage in forum 3geez Accords
    Last Post: 05-31-2009, 08:08 PM
  2. popping?
    By pervasto in forum 3geez Accords
    Last Post: 07-03-2004, 08:02 PM
  3. popping brakes
    By deadlight in forum 3geez Accords
    Last Post: 08-13-2003, 01:19 PM
  4. dipstick is popping out
    By GhEtTo 88 HB DX 5spd in forum 3geez Accords
    Last Post: 11-15-2002, 05:03 AM
  5. popping noise?
    By 86dxautohatchback in forum Carburetor Tech
    Last Post: 10-20-2002, 11:21 PM
