So, I'm looking for a little technical info on installing and testing a new TPS sensor. Picked one up from the 'yard, from a Prelude 2.0. The Honda Shop Manual doesn't have great instructions on which way to install the sensor, as to which way it goes into the throttle body correctly.
I got my Accord dirt-cheap because the guy I bought it from knew zip, and basically jimmy-rigged the entire car together. The shop manual shows a Throttle Stop Screw which I don't even have or see anywhere near my linkage, and it says to adjust the TPS to a position where the throttle stop lever just touches the stop screw, and then check voltage. Too bad I don't even have the stop screw to do that.
Also, it says to use a system checker harness to measure TPS voltage, but I know on my Trans Am, I am able to just back-probe the harness to check voltage and sweep from closed to WOT. Am I able to do the same thing with this Accord, and which wires can I probe?
Thanks,
-Dustin
