am I speaking some sort of foreign language? I never said intermediate shaft I said halfshaft, in other words the reman shaft with the two cv joints on it.
If you have even read any of this thread you would already know you do not buy interemediate shafts at parts houses.
I think that misunderstood and mistaken terminology is one of the biggest headaches of this particular swap.
Why did'nt you place these side by side in the same direction they were, it would be a lot better for us to tell the difference..
Im not bent,, lol,, sorry man. I have been banging my head over all of these b20 threads anyway.
regarding that picture of yours, it looks like the prelude axle is very close to a direct fit, why don't they? spline count on the hub side?
If you would take a picture of them with both on hub side out, we could see how they look.
I heard they pop out, like an inch or so different in length or something, maybe Carotman will come soon and reitterate.. lol
The two are really close but like Caotman said the splines on the prelude axle are slightly longer. Accord axle is at the top
As you can see, the prelude axle is a bit shorter. It could work but I didn't want to take any chances.
The Accord axle will not go all the way in because the splines are only on half it's length. That's why I said you have to use the prelude inner joint with the Accord axle.
I need these parts!
I found out also that my A20 exhaust has 2 holes for the intermediate shaft to mount. Does anyone think that Honda knew that this swap would be done?? Ha ha makes me wonder
the exhaust has a mount thingy to the block, not the half shaft. if thats what i think you're trying to say anyway. not sure
So Carotman all I need to make this work is #3 from the picture with a prelude intermediate shaft and a accord passenger side axle with the prelude spline?
Carotman do you know how to seperate the auto shaft from the axle? A18 is trying to figure it out
I need these parts!
bullard I hope you are not planning on mounting your int. shaft on the exhaust downpipe flange !
yeah all that exhaust bolt hole thing is for a bracket that bolts in betwen there and the block. yours has been removed, i also remove mine cause its a load of rubbish.
bullard have you sorted out your half shaft? im pretty damn onto it when it comes to accord axles. i have ran two right hand side A20 axles on my b20a without problems. just have to swap the inners so the one with the long splines goes into the half shaft and the other one into the gear box. have you got a half shaft there?? AT or MT?
Yeah I got the accord half shaft and the prelude half shaft. But I need the shaft support to bolt it up
So you dont have the metal bit that bolts to the block and holds the half shaft on
if you want to separate the shaft from the bracket, you need to remove a circlip
I need these parts!
another mate if mine needs one too. maybe ill see what i have in the way of halfshafts next time i am at mums
i removed the circlip and pulled out an auto axle to replace it with a DOHC ZC MT shaft and it worked
Carotman do you have any contact info or website info for anyone who sells just the half-shaft support?
