Results 26 to 50 of 75
Thread: B20A Intermediate shaft revealed
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: B20A Intermediate shaft revealed
    yep , that absolutley makes sense....
    I found several at the JY today, I thought I took everything I needed to get Lude upper arms and the shaft, EXCEPT the dam axle nut socket. I was PO. it is a long ride to the yard!
    If you get a reman halfshaft for a 3 gen prelude or 1gen integra, does it not come with that long spline? Can it be used just like it is on this Accord?
    Nope they don't sell the intermediate shaft at any part stores. I went looking for one yesterday
    Quote Originally Posted by bullard123 View Post
    am I speaking some sort of foreign language? I never said intermediate shaft I said halfshaft, in other words the reman shaft with the two cv joints on it.
    If you have even read any of this thread you would already know you do not buy interemediate shafts at parts houses.
    I think that misunderstood and mistaken terminology is one of the biggest headaches of this particular swap.
    Why did'nt you place these side by side in the same direction they were, it would be a lot better for us to tell the difference..
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Hey its all good man don't get bent all outta shape. Yeah I misunderstood you but that was my fault. I call them diver's side axles or passenger side axles
    Im not bent,, lol,, sorry man. I have been banging my head over all of these b20 threads anyway.
    regarding that picture of yours, it looks like the prelude axle is very close to a direct fit, why don't they? spline count on the hub side?
    If you would take a picture of them with both on hub side out, we could see how they look.
    I heard they pop out, like an inch or so different in length or something, maybe Carotman will come soon and reitterate.. lol
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Yes they look close. I'll take another pic of them soon. And yes Im gonna try to install the whole axle with the intermediate shaft to see if it fits
  8. #33
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    The two are really close but like Caotman said the splines on the prelude axle are slightly longer. Accord axle is at the top
  9. #34
    carotman's Avatar
    Montreal South Shore
    As you can see, the prelude axle is a bit shorter. It could work but I didn't want to take any chances.
    The Accord axle will not go all the way in because the splines are only on half it's length. That's why I said you have to use the prelude inner joint with the Accord axle.
  10. #35
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    I found out also that my A20 exhaust has 2 holes for the intermediate shaft to mount. Does anyone think that Honda knew that this swap would be done?? Ha ha makes me wonder
  11. #36
    the exhaust has a mount thingy to the block, not the half shaft. if thats what i think you're trying to say anyway. not sure
  12. #37
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Yeah it looks like the holes from the prelude intermediate shaft lines up with those holes in the exhaust. Im not sure but I'll know this weekend
  13. #38
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    So Carotman all I need to make this work is #3 from the picture with a prelude intermediate shaft and a accord passenger side axle with the prelude spline?
  14. #39
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Carotman do you know how to seperate the auto shaft from the axle? A18 is trying to figure it out
  15. #40
    carotman's Avatar
    Yes, all you really need from a JDM car is #3
    Usually you just need to pull on it
  16. #41
    bullard I hope you are not planning on mounting your int. shaft on the exhaust downpipe flange !
  17. #42
    yeah all that exhaust bolt hole thing is for a bracket that bolts in betwen there and the block. yours has been removed, i also remove mine cause its a load of rubbish.
    bullard have you sorted out your half shaft? im pretty damn onto it when it comes to accord axles. i have ran two right hand side A20 axles on my b20a without problems. just have to swap the inners so the one with the long splines goes into the half shaft and the other one into the gear box. have you got a half shaft there?? AT or MT?
  18. #43
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Yeah I got the accord half shaft and the prelude half shaft. But I need the shaft support to bolt it up
  19. #44
    So you dont have the metal bit that bolts to the block and holds the half shaft on
  20. #45
    OMG, can you break it down some, this is confusing yet again "inners" huh?
    thanks in advance
  21. #46
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Exactly! A18 had a hard time getting his off. Do you have one laying around?
  22. #47
    carotman's Avatar
    if you want to separate the shaft from the bracket, you need to remove a circlip
  23. #48
    another mate if mine needs one too. maybe ill see what i have in the way of halfshafts next time i am at mums
    i removed the circlip and pulled out an auto axle to replace it with a DOHC ZC MT shaft and it worked
  24. #49
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Carotman do you have any contact info or website info for anyone who sells just the half-shaft support?
  25. #50
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Carotman what tools will I need to change switch the prelude inner joint to the accord axle??
  1. Need 90-93 integra sk7-j intermediate shaft
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-21-2012, 11:33 AM
  2. intermediate shaft stuck in gearbox
    By A18A in forum 3geez Accords
    Last Post: 02-01-2011, 05:30 AM
  3. JDM B20A ECU revealed (PH3)
    By carotman in forum JDM B18A / B20A Swap Tech
    Last Post: 06-21-2008, 10:01 PM
  4. jdm b20a manual intermediate shaft wont work with quaife
    By mykwikcoupe in forum JDM B18A / B20A Swap Tech
    Last Post: 06-13-2008, 02:08 PM
  5. In need of b20a final drive and main shaft
    Last Post: 03-23-2008, 05:30 PM
