Results 1 to 25 of 28
Thread: Car overheats frequently!!!
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    If i let the car sit more than 5 minutes with the engine running and warmed up (Like in a fast food drive through) the car will heat all the way up at about 3 mm's below the Red line on my dash thermometer (or whatever you call it) , is this normal or is there something wrong??? plz help, oh and also, its usually like 90 degrees here all day so just letting you know.
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    The obvious: thermostat, hoses, bubbling coolant overflow tank, snapped belt on waterpump, etc.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    so its not normal? even in this hot weather?
    2006 Nissan 350z
    Does school count?
    no...
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    damn. maybe its my intake, i have short ram, it would be sucking in lots of hot air, still not normal?
    2006 Nissan 350z
    Does school count?
    No, and the intake would not make your car overheat, just run shitty with hot air coming in. Check your hoses and temp sensor if need be. Also, make sure that your fans are working and that there is no blockage restricting air. If need be, drain and refill your anti-freeze making sure to bleed any air in the system.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Jan 2004
    Bucket
    Bay Area, CA
    yah, wat zero said in the first post. check your radiator. if you don't know how to check the rest, take it to a shop, definitely a problem. even in 120 degrees weather with short ram, temp should read just under midway line. better get that fixed dude, overheating kills motors, pretty much the motor is shitty as of now and forever. unless it's the thermostat.
    3geez for life.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    damn. actually lately i havent heard my fans coming on at all! i was wondering why. hmmm shit. MY FANS DONT WORK!!!!!!
    DX User Xtracktor's Avatar
    Jun 2004
    1988 Honda Accord LX-I
    Check fuses? also, the relay under the hood.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    whats the relay? and how do i know i need a new fuse??? im gonna check the coolant in a sec, its under the radiator cap right?
    LX User tatmark1's Avatar
    87 honda accord lx
    Indiana
    what are you smoking man? where do you think the coolant goes?pull the fuse andlook to see if its burnt out
    1-2-0 mma nhb
    4-2-0 judo
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    ok i have a major problem. i checked the relays and fuses, one fuse was blown replaced it, and then i took the radiator cap off and i looked and there was light brown colored shit in it!!!!!! i think i blew a fucking head gasket!!!!!!!!!!!! im getting my dad to check it now...
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    nvm!!!!!!! that was RUST! its fine now, replaced fuse, and put antifreeze , its fine now, im gonna take the car for a drive and heat it up, then cut it off and see if the fans cut on when it cuts off.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    mmk i just took it for a spin and got home, cut the car off, dont hear fans running, but i was only out for 5 mins. i guess they'll be fine, thanks for all your help.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    oops, now i see green shit all over the ground! ... another fuckin problem.
    Jan 2004
    Bucket
    Bay Area, CA
    your fuckin radiatior fool!!!
    3geez for life.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    or its when i overflowed it. but there is more on the ground than the overflow
    87 honda accord lx
    Indiana
    wire you fan to a switch so you can turn it on.if yor rad. just has a small leak you could do what i did and pull it out and solder the hole shut
    1-2-0 mma nhb
    4-2-0 judo
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    ok wiring the fan switch sounds cool. more dashboard switches! i know how to wire switches and everything but where do i run the accessory to? the relay? dunno, help!
    87 honda accord lx
    Indiana
    at the bottom of rad to the left of car in the sensoe it has a blue wire and a black with2 red stripes, cut those but leave enough so you can put wire back onto sensor f need be.take those wires that went to sensor and run them into cabin to a switch thats it works fine. maybe other ways but thats what i did
    1-2-0 mma nhb
    4-2-0 judo
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    hmmm my friend says i can hook it up to the relay? dunno, does that sound easy?
    87 honda accord lx
    Indiana
    you want easy? do it like i said doesnt get any easier
    1-2-0 mma nhb
    4-2-0 judo
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    ok so cut off the black (With 2 red strips) wire, and put it to the ground on the switch. then take the blue wire and put it in the Accessorie or the Power? which one? or do i have to make a power wire to the battery?
    87 honda accord lx
    Indiana
    get a switch with 2 termanals and just connect the damn things to it and your good
    1-2-0 mma nhb
    4-2-0 judo
  1. 86 Accord LX Overheats a lot..
    By DeViOuS in forum 3geez Accords
    Last Post: 04-14-2005, 05:34 PM
  2. Primary fan won't come on, overheats
    By Boogerbub in forum 3geez Accords
    Last Post: 04-10-2005, 10:44 AM
  3. HELP car overheats
    By asianimports69 in forum 3geez Accords
    Last Post: 03-08-2004, 07:38 PM
