Results 1 to 7 of 7
Thread: Help not that i use it but my cruise control stopped working
    Mar 2002
    1989 Fn' Blue Honda Accord Lxi 4dr
    Charleston, WV
    I was using it like a month ago worked normally....i dont use it much cause well we have mountains and its not really fun...only when im tired...but i was wondering what i should check...the switch turns on but it wont set or turn on the dashboard light..any suggestions...i just like everything in my car to work..i already checked the fuse..hope it was nothing to do with my breaklight troubles
    "But no matter how much you tune it, it is still just an 86."
    Kyoichi Sodou
    ~Initial D
    MOds: bunch...if you see blue streak by catch up to me and ill show you ^_^
    Millington, TN
    I'm in the same boat.
    Haven't really look at everything, but if I get around to it I'll keep you posted.
    Check your vacuum hose leading to your Actuator
    Then all your connections
    Then your actuator
    Then your set switch
    Hopr this helps
    Phil
    1990/BMW/535iA
    New Orleans, LA
    Also, what kinds of brake light problems are you having? If the pedal switch is defective, it may prevent the cruise control from engaging. Same goes for the clutch pedal switch.
    3axap.
    chicago , il.
    one question does your horn work??
    Mar 2002
    Charleston, WV
    horn works..i also made a post about my brakelight problems
    Kyoichi Sodou
    ~Initial D
    DX User SavageG's Avatar
    Jul 2004
    86' Accord Lxi, 79' TR7, 73' VW bus, 03' WRX
    Portland, OR
    Have you checked the switch under your brake pedal? Try adjusting it foward (so the pedal applies more preassure to the switch) this worked when mine went out.
    1990/BMW/535iA
    New Orleans, LA
    Quote Originally Posted by SavageG
    It seems that Micah fixed the problem already. There was a wrong type bulb installed in one of the tail lights that caused the cruise control and the light issues.
    3axap.
  1. Horn and Cruise Control not working
    By marklj in forum 3geez Accords
    Last Post: 09-16-2011, 05:50 PM
  2. Cruise Control Not Working
    By TWOLOUDNPROUD in forum 3geez Accords
    Last Post: 07-02-2006, 11:05 PM
  3. cruise control stoped working
    By ACCORD1.8CARB in forum 3geez Accords
    Last Post: 08-07-2005, 04:49 PM
  4. Cruise Control Not Working...
    By my89accord in forum 3geez Accords
    Last Post: 07-17-2005, 05:33 PM
  5. Cruise Control Not working
    Last Post: 09-28-2004, 02:39 PM
