ok ..this has pissed me off for 3 months now - car doesn't idle like it should when warm : after releasing the pedal, rpm falls and car usually dies in 3 seconds..someties it's suffering @ 300-400 rpm for 6-10 seconds and then dies. I have to press the gas pedal to keep it alive.It's especially weak, when i'm sitting behind the traffic lights and revving up my shitty stock 3g like a n00bass ricer who wants to beat the BMW 535 waiting next to me.
Even when i try to hold it still @ 1000, rpm varies from 800-1200. When engine is cold, it works very steadily and nice @ 2500rpm, then 1500rpm.
Also this is happening: when i floor my 3g on the road, it pulls my ass off, but when it wants to go over 3000 rpm or so, car wants to die...like it's out of gas..and an assload of black smoke comes out of muffler if i keep th epedal down. akfter releasing the pedal or pressing it gently it drives on like normal. I'f i'm accelerating like a 70-year old nut, it goes nicely to 3500rpm
This especially pissy off, when i want to drive pass somebody, and when i'm next to them car starts bitching and i have to cancel my attempt and pull over for 1 minute and let the car rest
I'f i'm floor the pedal while idle'ing, it goes nicely and fast upto 8000rpm or so...no problems..and comes down..to 0 rpm if i release the pedal
So any ideas wtf is wrong with it?
Info about my 3g:
'86 Aerodeck ,A20A2 engine, vaccuum removed 1 year ago (worked fine after this setup ~9 months so nothing wrong with that), no air filter or airbox at the moment, no cat, empty muffler, stock engine, shitty old plug wires
Things i have checked or replaced:
*new NGK-r plugs,
*new fuel filters,
*cleaned the carb (maybe i did it wrong and vacuum is leaking from the seal?)
*checked for vaccuum leaks but didn't find any,
*checked the radiator and coolant = they're working and engine doesnt overheat,
* checked choke plate = this opens like it should
* checked venturies = they're tight and dont move
So what's this: is my fuel rail or fuel pump crappy? is it a vacuum related thing? I have no ideas
So any help would be appriciated ,guys.
