You have primary and then secondary. Remember the coil is a transformer which is basically a step up transformer. There are more windings in the secondary cct. The aftermarket coil should meet the same resistance in the factory specifications. primary resistance is checked by putting a ohms meter between the +ve and -ve of the terminals.
Well the thing is depending on what kind of system the older ones had an internal ballast resistor or some had external ones. I would assume a non ballast resistor type coil has aprox 1 ohms or so and the ones with an internal ballast has 2-4 ohms. I think the claim of having too a high primary resistance will create a miss is bullsh!!
resistance may effect how the primary voltage energizes the primary coil. The MSD systems use the HVC coils in the digital 6 units to engergize the primary faster with low primary resistance. Too much to discuss but basically get a coil with close to factory specs.
