Page 3 of 27 FirstFirst 123456713 ... LastLast
Results 51 to 75 of 665
Thread: Ignition Coil Thread (UNDER CONSTRUCTION)
  1. #51
    GDGuy11B's Avatar
    Jul 2001
    1989 Accord LX-i, 00 Civic EX
    Back from Baghdad (Tallahassee)
    i know they're the same thing, my post was meant to be funny.
    89 Silverstone Metallic LXi, custom Air Intake, DC Sports 4-2-1 header, A'PEXi N1 exhaust with 2.25" pipe, ACT clutch, Xenon body kit
    3geez member since July 11, 2001
  2. #52
    Oct 2001
    87 Accord EX , 5spd , Manual
    Re: what is an accell coil?
    Originally posted by jkim1978
    what is an accell coil do? cause everybody on this board is talking about it.. and i don't have the slightest clue what that does... and also... after i hear about what the coil actually is... how much is it... and where can i get it...
    an ignition coil is a device that converts the 12 V power from the battery to 12000 volt to feed the spark plugs which ignite the air and fuel in the engine !
    Accel coil is just a type of ignition coil !
    hope this helps !
    MIKE
  3. #53
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    Sorry if I had a little trouble sensing the sarcasm, but mine was meant to be funny too, so......
    Hey Mike.....Air is flammable? I didn't know that! :p
    -Aaron-
  4. #54
    Oct 2001
    not like some other gasses ! :d :lol ( if you know what i mean ! )
    J/K
    MIKE
  5. #55
    Jun 2002
    86 accord 4 door LX
    Honolulu, HI
    changed the ignition coil still chugs
    still chugs in 3rd gear, can't bring it past 4k rpm it does the same thing in 4th gear, never tried 5th not enough road to bring it past 4k rpms , could it be rev limiter?
  6. #56
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    what do you mean get it past 4k? it stops? check your wires,plugs,rotor,button,fuel filter, and the dreaded...carb adjustments
    I havent forgotten my roots
  7. #57
    2.0Si User accordlx's Avatar
    1988 Honda Accord LX, 2006 Honda Ridgeline RTL, Pontiac Sunfire Convertible, & 1979 Corvette
    Cincinnati/Columbus Ohio
    I agree, I would move on to the plugs, wires, rotor, and distributor cap. You aren't getting enough spark. If I had to take a 1 stop fix on this, I would get the distributor cap and rotor at this juncture.
  8. #58
    Oct 2001
    what did you change in your engine ( replaced with new !)
    MIKE
  9. #59
    shepherd79's Avatar
    Falling Waters, WV USA
    well,
    apparently it is eather your timming is way off,i mean way off.
    or you need a good tune up.
    check your timming. you can rent the light at the autozone for free.
    get NGK spark plugs and wires. new cap and rotor.
    i can push mine in 3 gear to 6000rpm/ 90mph. no problem.
    you should be able to do the same thing.
  10. #60
    Jun 2002
    86 accord 4 door LX
    Honolulu, HI
    I had already changed the spark plug wires (ngk) and plugs (ngk) changed the distributor cap and the cap rotor, also changed the ignition coil just yesterday, still can't get it past 4k rpm in 3rd gear I think I'll get the carbeurator checked, oh and the car still has a hard time starting from cold, I gotta press the gas pedal once then turn the key then hold the gas down for a while or the engine will die from cold start, but yah the car still can't go past 4k rpms in 3rd or 4th.
  11. #61
    1/2 JDM B18A DOHC CARB
    MD
    Don't expect big power increases when you put one on, it does help some in throttle response and starting up, but you'll really see a difference if you combine it with other engine modifications.
    Carl
  12. #62
    1988 Honda Accord
    Ontario, Canada
    Performance Coil??
    So if I wanted to get more spark, I can get JUST the coil? Or do I need other stuff? I noticed you can get an amplifier.... can I get JUST that or do I need something to go with it. I see alot of you guys have aftermarkey coils and I was wondering if is worth it, and how I should go about getting one.........
    I figure if I'm dumping more air/fuel into the motor with my weber, I should give er' some more spark......... make sense?
    CoAsTeR
    88' Honda Accord LX
    www.coastersride.cjb.net
    Visit my website for pics and how-to's
  13. #63
    Jun 2002
    1989 Honda Accord HB DX
    Studio City, CA
    Please...somebody reply with more information on this. I want to buy a MSD coil. Should we get the amp as well? How much are we looking at? What model number?
  14. #64
    shepherd79's Avatar
    well,
    i have the accel coil. I got mine from Pepboys. If i remember right it was like $30 plus tax.
    I know if you want MSD one you may want to putt out a little more.
    it would be nice to get MSD amp, but try with out it first. sometimes it is enough.
    i would recomend get colder spark plug. i am gonna get for myself tomorrow.
    i don't know what model of MSD you need, i have to look at the catalog at home( i am on vacation right now). But i know the accel coil is 1240(yellow) or 1240C (crome).
    don't forget to change the gap on the spark plugs or you will burn them.
    good luck.
  15. #65
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    I think the output of the coil is determined by the amount of secondary winding's it has and strength of magnet.....more winding's.....higher output(>30,000v)......bigger spark at plug's
  16. #66
    LXi User Jerren's Avatar
    Jul 2001
    1991 H23 powered Accord EX Wagon , Turbo 91 Honda CRX, and 96 Blazer LT
    St. Louis
    i had the same question. so how much do they cost?
  17. #67
    MD
    They can cost between 30-40 dollars.
    Carl
  18. #68
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    where can you get a MSD Coil... are they universal....and how hard is the install??? Thanks...
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
  19. #69
    accord HB ( metallic green)
    B.C Chilliwack
    its pretty easy to install - just check the how too's
    I got a msd blaster2 and it only took about 20 min to put in
    You can get them at any auto parts store and i think they are all universal
  20. #70
    1988starter
    Guest
    I have also sceen them cheep on ebay I got my gf's coil their for 9.00
  21. #71
    1988starter
    Guest
    Yea I got the accel and changed my gap to .054 it works well but I was thinking of getting a MSD SS coil anyone have experience with them.
  22. #72
    88 LX Action
    Podunk, Alabama
    accel coil question
    whats the difference between the round super coils, and the squarish accel super coils? there all universal for any ignition, right? thanksss
    real 3geez http://www.3g-generation.com
    i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
  23. #73
    1988starter
    Guest
    I think the square ones are for larger engines I remember my old 350 had a big square one.
  24. #74
    Jun 2002
    Studio City, CA
    Talking While you're answering the ACCEL coil question...answer this MSD coil question.
    When shopping for a MSD Blaster 2 Coil.....must you purchase the one with or without the BALLAST resistor?
    These items can be found at http://www.partsamerica.com/ !!
    1989 Honda Accord DX Hatchback - 155k miles and going.
  25. #75
    88 LX Action
    Podunk, Alabama
    do you know if the universal square ones would work if i could get one real cheap?
  1. ignition coil
    By firefighterwhite89 in forum Restoration & Custom Fabrication
    Last Post: 09-25-2011, 05:40 PM
  2. Ignition coil
    By DEEGO in forum Performance
    Last Post: 03-24-2009, 11:25 AM
  3. Ignition coil
    By steveko in forum 3geez Accords
    Last Post: 01-14-2008, 08:33 PM
  4. My New Ignition Coil
    By sinisterfuzzy in forum Performance
    Last Post: 08-21-2006, 03:02 PM
  5. Ignition System Thread (UNDER CONSTRUCTION)
    By Techno in forum Performance
    Last Post: 08-02-2004, 08:02 AM
