Page 5 of 27 FirstFirst 12345678915 ... LastLast
Results 101 to 125 of 665
Thread: Ignition Coil Thread (UNDER CONSTRUCTION)
  1. #101
    1988starter
    Guest
    .044
  2. #102
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    is it ok to gap it lower than stock?
  3. #103
    1994 Honda Accord, saving up for 2004 Subaru WRX
    Massachusetts
    or.. yanno... NO ONE CAN ANSWER ME!!!!
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
    PERFECT Maroon Interior
    Call or Contact Dan @ 1-617-893-8320 or E-mail at [email protected]
  4. #104
    Massachusetts
    Question About that Accel coil......
    now when i go to buy my new Accel coil.... what am i asking for??? should i ask for one for an 88 accord or is a universal thing? like ever car can use it? yeah... ALSO.. im planning on gapping my plugs around .05~.055.. is this cool??? just a week ago i put in new stock NGK plugs.. so it this alright to use? thanks
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
  5. #105
    Feb 2001
    '87 Accord LX
    Renton, Washington
    They're universal, but you don't want the one with the internal ballast. Your spark gap looks good and good plugs so go for it.
  6. #106
    1988starter
    Guest
    I guess you could many people do who have forced induction but I do not see how it would help a regular car.
  7. #107
    1989 Honda Accord Dx
    Miami florida
    THe less the gap is the better or the more the gap is the better cause i put an accl coil and i didnt gap the sparkplugs at all i just bought them and put them on .. and what should i gap them too if i want more power "low end torque for an automatic..
  8. #108
    shepherd79's Avatar
    Falling Waters, WV USA
    yeah, the coil is universal yellow or crome color. i think it is 1240 model or something like that.
    and spark plugs should be just fine.
  9. #109
    1988starter
    Guest
    The part number is 8140 for yellow or 8140c for crome
  10. #110
    1988starter
    Guest
    From what I understand less for forced more for normal and you should alaways check your plugs gap before install.
  11. #111
    1988starter
    Guest
    keep the NGK and the .050-.054 is fine
  12. #112
    1988starter
    Guest
  13. #113
    Massachusetts
    Question ok...ACCEL, am i missin' something???
    well... i installed my Accel coil... im running Blue Thunder wires... NGK .o57 gapped plugs.. im noticing no differance in ANYTHING with the car's performance.. i heard i was supposed to get a little bit better pull... at least some more low end torque... (marginal amounts of course) but the only differance i see is it idles around 500rpm instead of 700rpm... so am i missing something??? thanks!
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
  14. #114
    10/Honda/Ridgeline
    NJ
    advance ur timing 3 to 5 degrees.
  15. #115
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    if it runs good then you did it right... the plug gaps may be too high or still too low tuning the gaps take time... high gaps don't even need to be used on our engines even with a performance coil... with a modified engine then high gaps will make a difference. for us the coil will just equal consistant spark and or better gas milage. I think most of the performance gains came from the changing of the plugs and regaping them... it sort of cleaned off the old deposits and made the car run smoother.... a 500 idle is nice.
  16. #116
    1988starter
    Guest
    Did you put the yellow wire on the positive side and the blue on the neg side also try shortning your gap.
  17. #117
    Massachusetts
    how do i advance timing? and if i do how do i NOT fuck it up?
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
  18. #118
    1988starter
    Guest
    I wrote about it somewhere one sec
  19. #119
    A20A1's Avatar
    Sep 2001
    you really should get a timing light to advance timing
  20. #120
    1988starter
    Guest
    here look at the first page about half way down
    https://www.3geez.com/showthread.php?s=&threadid=4325
  21. #121
    1988starter
    Guest
    I drew an 3/16 inch mark and adwancdt the bottom of one mark to the top of the other if I needed to go back I would just reset it to the mark well I made two to be sure.
  22. #122
    A20A1's Avatar
    Sep 2001
    make sure the car has warmed up first since the cold car and carb will give you a temporary rich mixture which will resist ignition.
  23. #123
    1988starter
    Guest
    Thanks A20A1 I think I missed that in my writeup I knew I might miss a thing or two that Is why I asked people to tell me If I did.
  24. #124
    Massachusetts
    well i ran blue to negative... and black and yellow to positive... umm as far as advancing the timing i dont think i'll take it that far... but i do think i'll back down the gapping a little... i'll probably take it down to .05 dont wanna go to big.. ... also... i noticed that my engine tone got lower... probably considering that it's idling at around 500.. however.. even when i rev it it sounds more powerful.. and when im accelarating (tearing down main st.) i notice a whole nother engine sound.. i mean it sounds so much better than it used to... HENCE why i think it's about time to get me a muffler (heh heh) ... im thinking about one from speedpeople.com it was on sale this weekend for 89.99 with scilencer... sound cool? it's a tube, basically, says it has a good low tone which is what im looking for... i think im goin for it .. thanks for the help gents... ANY OTHER SUGGESTIONS PLEASE TELL ME.... i'll post a thread... later
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
  25. #125
    1988starter
    Guest
    Well make sure you have all 4 wires hooked up.. My friend's Tempo made a totally different sound when we put his on. And defantly try lowering your gap a little.
  1. ignition coil
    By firefighterwhite89 in forum Restoration & Custom Fabrication
    Last Post: 09-25-2011, 05:40 PM
  2. Ignition coil
    By DEEGO in forum Performance
    Last Post: 03-24-2009, 11:25 AM
  3. Ignition coil
    By steveko in forum 3geez Accords
    Last Post: 01-14-2008, 08:33 PM
  4. My New Ignition Coil
    By sinisterfuzzy in forum Performance
    Last Post: 08-21-2006, 03:02 PM
  5. Ignition System Thread (UNDER CONSTRUCTION)
    By Techno in forum Performance
    Last Post: 08-02-2004, 08:02 AM
