Hey i've been doing a tune up, is there ne thing else I should do?
i've done plugs n wires, coil, cap n rotor, o2 sensors, air filter, oil change n filter, fuel filter, pcv valve, tire pressure, and valve clearences.
ne thing else I should do?![]()
Hey i was wonderin how hard it is to install a new fuel filter and how much a Fram or Purolator or anything would cost? do you know?
Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
oh, another thing for your tune up= if you have an EFI engine put some FI Cleaner in your gas tank.
fuel filter is easy and it helps out a lot, just release the fuel pressure then unscrew it and put the new one on, you should just get a shop manuel
check the timing, and adjust as needed, change your fluids ( oil, flush the radiator, ect.. )
*** If your not willing to spend the energy to get what you want, at least spend the energy dealing with what you have ***
i've done the belts and a few seals, i'll check the timing and change out a few fluids, what should I clean the throttle body w/ ?
do u just spray it inside the tb? with car running? off? or just plain spray and wipe off insides?
i would take the TB off and clean it all out but mainly around the butterfly is what you need to clean, and there are a few ports that like to get clogged that you have to take off the TB to clean. i like to do this, i dont know if you need to, but i do.
damn just went to get a new fuel filter that shit is 21 bucks, f that. ill get it next week.
cleaning your TB you can just use carb cleaner spray. I think it works well enough =)
