Results 1 to 9 of 9
Thread: Starting to piss me off...
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    Damn, my car is idled really high, (1500 in park, 1100 in drive) and when it goes a little over 1500 it drops to zero then goes back up then it hits over 1500 and drops again, and again, and again until i cut the damn thing off for a minute and restart it. I see the yellow marked screw on the throttle thing but i cant get to it!!! arent you supposed to turn it to the left or right to idle it down? hmm anybody know how to idle it down the easiest way?
    Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    I belive turning it to the right lowers the idle and turning it to the left raises it. You can't get to it¿ You should be able to take a long flat head screwdriver and that should make it possible to get to it.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    like, the end of the screw is facing downward and there is like no space anywhere, i think i have an idea, might ruin a butterknife though. i will bend the tip of a butterknife and use it that way if it will work.
    2.0Si User Elijah's Avatar
    Nov 2002
    A20A3T
    Edmonton, Ab, Canada
    I just had the same problem.And it was my idle screw.The screw does not face down.It faces toward to passenger side of the car.Some times it is a little tricky to turn because of a red vaccum line.
    Feb 2005
    1989 Accord exi 2 dr coupe
    near Montreal,Que (canada)
    Exclamation IAC Valve
    Got an 89 exi(cdn model) coupe w/4spd auto. When I got it two yrs ago it would do same thing. Idle wouldn't hold and would drop to 550rpm or so & then jump to 1500-2000. A complete tune up later still did same thing hot. Found the fix. Run to oper temp (cooling fan on), turn off, disconnect IAC valve cnctr, restart & adjust idle screw on tbi to idle rpm (750-800) Turn off, reconnect IAC & with full load (lights a/c wipers etc) fine tune idle screw to 750-800 rpm. Worked for me!
    YK86's Avatar
    Oct 2000
    BC, Canada
    Could also be your fast idle valve (on the back side of the intake manifold). A bad or dirty one makes the idle lope alot and it happens to almost every 3rd gen I've worked on. Check Paul's online manual for how to clean it.
    www.b20accord.com
    Idaho
    Check your PCV valve too, mine was bad, and she ran like poo. High idle and sparatic idle.
    Jan 2004
    1986 Honda Accord LX
    Tampa, FL
    I'm having a similar problem. Where exactly is this yellow screw located? Can someone send a picture or a link?
    1st 3rd Gen -R.I.P.
    Blue 87 DX Sedan - MT
    Died @ 215K
    2nd 3rd Gen
    White 86 LX Sedan, 92K Auto, Limo Tint, New Paint, Sony HU w/stock components.
    Bought that beaut for $1K straight up.
  1. Things that piss me off about accords, particularly 4gs
    By AccordEpicenter in forum Classic Honda Community Chat
    Last Post: 12-24-2003, 07:47 PM
  2. Lesson #1...NEVER PISS OFF UR GIRLFRIEND!!!
    By Rosen99 in forum Classic Honda Community Chat
    Last Post: 06-02-2003, 07:39 PM
  3. son of a... This is beginning to Piss me off!!!
    Last Post: 08-19-2002, 09:53 AM
  4. piss me off!!!!!!!!!!
    By 87hatch in forum Interior & Exterior Care
    Last Post: 06-10-2002, 07:17 PM
