Results 1 to 21 of 21
Thread: How much HP could i make
    Feb 2004
    88 LXI hatch-totaled,new ride 89 DX
    Pittsburgh,PA
    Just wondering about how much horsepower could i make with a weber carb, header, 2 1/4 inch exhaust, and a high flow cat. THANKS
    It's not a drinking problem it's a drinking solution.
    May 2004
    1987 Honda Accord DX
    Mankato, MN
    145 hp is my guess, but I can't even get my car to go anywhere so what do I know :P
    Feb 2004
    Pittsburgh,PA
    145 thats pretty good are you serious?
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    115 - 120 more like
    the weber isn't tuned out of the box either, and I would suggest you upgrade the pump, it helps get rid of the dead spot on acceleration.
    Feb 2004
    Pittsburgh,PA
    what kind of fuel pump would i need?
    A20A1's Avatar
    Sep 2001
    I believe most weber guys went with the holley pumps, you may need a regulator to get the psi down to 3.5 but problem is finding one that does...
    Holley Red
    http://store.summitracing.com/partde...%2D1&view=2047
    Holley Blue (Comes with regulator)
    Aeromotive regulator (expensive but has 3 - 20 psi adjustablility and has 2 outlet ports which means you can hook the fuel psi gauge to the second outlet)
    http://store.summitracing.com/partde...3301&view=2047
    Holley Regulator (4.5 - 9 psi)
    http://store.summitracing.com/partde...D501&view=2047
    Summit Regulator (4.5 - 9 psi)
    http://store.summitracing.com/partde...3131&view=2047
    Auto Meter Gauge (0 - 15 psi You'll probably want this to set your fuel pressure correctly it has a 1/8 npt fitting so you need something to hook it inline with the fuel line or the outlet port of the regulator)
    http://store.summitracing.com/partde...428A244C64C%7D
    In-line adapter for gauge
    http://store.summitracing.com/partde...1710&view=2047
    Regulator gauge adapter
    http://store.summitracing.com/partde...5310&view=2047
    Feb 2004
    Pittsburgh,PA
    that helped alot, thanks
    May 2004
    Mankato, MN
    Errr I was thinking 120 hp stock..... not 98.. where the hell did I get the 120 number from?
    A20A1 is my hero. <3
    k-roy's Avatar
    87 LX
    If you want some good power you should at least work on the ignition and timing.
    Get some thick ass wires, new coil and a reground cam. With what you listed plus this 145 HP is more feasable.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by Wipeout
    You were think of EFI.
    May 2004
    Mankato, MN
    Oooooohhhhhhh okay. Damn, 22 hp improvement. Instead of buying a Weber it sounds smart just to convert to EFI. Is there anything else different about the engines, like cams or anything?
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    If you tune the carb correctly you will pretty much be matched to FI stock or better.
    Hey Mike can I hook up that holley fuel pump in my engine bay? Is it easy not to have an intank pump?
    Thanks,
    Mike
    A20A1's Avatar
    Sep 2001
    I still think the carbs have it... I will continue my modification https://www.3geez.com/showthread.php?p=438683
    A20A1's Avatar
    Sep 2001
    I think you need to remove the stock pump and then add on a section of new pipe to complete the pickup...
    maybe upgrade the line size a little while you are at it but that envolves removing the old pipe and bending a new one.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Quote Originally Posted by A20A1
    I think the better answer is carbs DON"T have it. You can do wonders without an ECU putting a wall infront of any MAJOR horsepower increases
    A20A1's Avatar
    Sep 2001
    True but he's talking about converting to Stock efi... which includes the ecu... if it were something else like ITB's or anyother custom injection setup then I wouldn't have said anything.
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    i was about to say DAMN! that would outrun an EFI anyday!!! but then i was like no way thats not possible there kidding around...
    Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
    A20A1's Avatar
    Sep 2001
    who's kidding around?
    Mankato, Minnesota
    Carbs are more powerful IMO. It's just that hardly anyone knows how to tune them properly. I will always have a carbed motor.
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    oh yea, after a20a1 vac removal, and added some part's afterward's, that car had some ball, yet conserved more gas than it did when i first got it.
    but still converting to efi.
    ****** 1994 nissan maxima SE ******
    May 2004
    Mankato, MN
    Yeah my car is a little faster after the vacuum removal and a few other things. Mike, when I get back to Minnesota you should help me tune my car so it idles and stuff. lol
  1. how to NOT make your three g look better
    Last Post: 05-15-2008, 12:50 PM
  2. how do i make my car run better????
    By salgmz in forum EFI Tech
    Last Post: 09-04-2006, 12:47 PM
  3. Make your own CAI
    By 87LXiR in forum Performance
    Last Post: 04-11-2006, 11:59 AM
  4. just make your own c.a.i.
    By blaztR in forum 3geez Accords
    Last Post: 02-13-2006, 06:17 PM
  5. make over
    By Js2000'sbrother2 in forum Classic Honda Pics & Videos
    Last Post: 06-10-2002, 07:27 AM
