Whats the proper way to take all those vacum hoses and emmisions boxes out. what hole do I have to plug and what will it do for my car, besides make more space (thats why I want to do it).
Oh I have a lxi manual 89'
you can eliminate the charcoal canister and stuff by removing the canisters and connecting the two no.12s and plugging no.3
I havent forgotten my roots
its just a start but ive...
blocked the egr
remove canisters
removed all a/c components
i cant stand a cluttered engine bay
Is it possible to eliminate that emmisions box near the firewall. And how do I block the egr, and what will it do.
um.. no use of search?
Yes you can. Just remove the MAP sensor from the box, and hook it back up - one vacuum like to the throttle body. You might also want to think about leaving the cold idle advance sensor in place if you want a good idle at start up.
Look up on Paul's site and look at the configuration for the KX (I think??) Accord there. No emissons equipment, only the MAP and cold idle are there.
who's Paul and whats the name of his website?
HERE ya goOriginally Posted by 3gboricuaRACER
ok just finished this...
1)no 21 goes to the map. its a little 2''x2'' box thats says "denso map no.1"
2)hook the two dist advances together and run to the RIGHT SIDE of the manifold.
3)hook the EGR vac to the manifold or the TB ( sends it some signal to keep the CHECK ENGINE light)
4) YOU WILL LOSE YOUR SECONDARY BUTTERFLYS ( actually they stay open, kill a hair of low end power)
5) you should have no check engine lights and car should idle at 400-600 when cold
thanks alot vinny and moonscryer! in my thread i didnt get nearly as much help!![]()
if u go with a weber carb that get rid of all the vacumm hoses,andthe egr all i did was made a plate and put some hi temp sliocon
How come you lose the secondary butterflies... all they need is a manifold vacuum source to close them at idle and low throttle.
Hook them to the right side of the manifold and be done with it..
What exactly does the canisters do, aren't they filled with charcole¿
"Popup headlights the pinnacle of 80's technology"
Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
i was referring to EFI guys..... you know i dont have a carb car no more...
and the thread-starter also drives an EFI
I know you have EFI... So do I, I just don't use it... I know how the secondary operates.
