do i connect this to anything after i take out the stock intake box?
i couldnt figure out what is it for anyhow?
H4 Headlight Housing
6000k HID Conversion Kit
Strobe Light Kit in City Light Housing
Clear Corner Signal Lamps
Tinted Bumper Signal Lamps
Hyper-White Reverse Lamps
its parts of the EGR sys! Leave it alone since you live in crappy ...i mean cali
I havent forgotten my roots
it connects to the stock intake box... connect it to the civic box???
first pic is the silencer tube, connect it to airbox if you dont' want the annoying bubbling sound. second pic is the pcv hose, it's suppose to put burnable gas and fumes into the airbox for combustion. you can cap if off with an oil breather filter (pepboys, kragen's) but make sure to get the stock set up back for emission, if the pcv is not connected you won't pass.
3geez for life.
k heres a better picture
well when you had that stock air cleaner, that was connected to the air it sucked vacuum that blow's into the exhaust manafold.
i took mine' off (86lx) or you can leave it on. it just sucks air from the intake intop the exhaust.
if you wanna get rid of it then follow the black box to a metal pipe that has a valve mounted on top of it. dissconnect the vacuum line and plug it.
to be honest without it the engine bay sound's alot quieter.
****** 1994 nissan maxima SE ******
Yeah the Air suction pipe... you can connect the silencer to the air box/intake if you want... or you can disable the vavle by capping the vacuum line to the diaphragm thats by the valve cover oil cap... I think it's #5... not sure though.
Don't cap the diaphragm itself, cap/plug the vacum line to the diaphragm.
#5 is affirmitive. I just put a nail in it![]()
I'll take a look at that this weekend. Thanks for all the help!!!
