Results 1 to 5 of 5
Thread: Transmission Problem...
    LX User Jonessoda27's Avatar
    Mar 2004
    87 Champagne LXi
    Washington
    I've just noticed on my AT transmission that when you shift from like R to N the transmission makes a wierd sound like crrrrkk, its kinda like a scraping sound.. what can this be? It also happens between shifting to other positions, but i don't know if it sounds worse or not?
    What can this be??? Is my transmission screwed? Im so fuckin pissed right know... Do i have to replace my transmission???!
    Silv'
    Nov 2002
    Ridin Dirty in New York
    does it just grind for like .5 second when you shift it from P to R or R to D or N or whatever? If continues to ratchet and grind for a few secs that bad but if it just grinds a little for about a half second then thats normal.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    If it's loud, something isn't lining up right... it's odd that dropping it to neutral would make a sound.
    There was one instance where I went from D4 into Park... that made a crrrrkk noise...
    It could be that your shifter cable isn't adjusted right, but it would probably only make noise from D3 to 2... or N to R or N to D4
    Have you checked the fluid?
    Mar 2004
    87 Champagne LXi
    Washington
    Quote Originally Posted by A20A1
    The tranny fluid??? What color is it supposed to be? Mine is pretty dark
    Silv'
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    The fluid should be clear-red in color and should not smell burned. If it is dark or smells burned, replace it. It may also be beneficial to flush the tranny by changing the fluid repeatedly within 50-100 miles or so.
    3axap.
  1. Transmission problem
    By honda crew in forum 3geez Accords
    Last Post: 02-02-2012, 08:29 PM
  2. Transmission Problem
    By Hans in forum 3geez Accords
    Last Post: 05-12-2007, 08:52 PM
  3. Transmission Problem.
    By dalinxz in forum 3geez Accords
    Last Post: 06-18-2006, 05:06 PM
  4. Transmission problem
    By 89D16a6 in forum 3geez Accords
    Last Post: 05-04-2004, 12:11 PM
  5. transmission problem
    By 3ightball_EXI88 in forum 3geez Accords
    Last Post: 08-20-2002, 02:24 AM
