Results 1 to 3 of 3
Thread: Instrument Cluster Lights DONT WORK! FUSE KEEPS BLOWING! NEED HELP!
    LX User JFreddy's Avatar
    Mar 2004
    1989 Honda Accord ex-i
    Airdrie AB, Canada (By Calgary)
    Thumbs down Instrument Cluster Lights DONT WORK! FUSE KEEPS BLOWING! NEED HELP!
    Ok, so this is my problem. I have a 1989 Honda Accord EX-i. My lights behind my speedometer and rpm guagedont light up anymore, so i checked the fuse and sure enough it was blown, so i replaced it thinking everything was fine... it blows another fuse... so itry a 20 amp fuseinstead of a 15... blows that... what is wrong and how could i go about fixing it????
    It's not what you drive, It's that you drive what you got! I LOVE MY 3Gee!
    Moodybluesr's Avatar
    Jan 2004
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    I had the same problem in my 90 EX one time and it ended up being and incorrectly installed dimmer wire on an aftermarket deck. If you have an aftermarket deck try unplugging it and seeing if that stops the fuse blowing problem. Otherwise it sounds like you have a short somewhere in that circuit and you're just going to have to find it.
    Mar 2004
    So if i take out my deck, and then it stops blowing fuses, how do i fix it so i can still have my deck, and it wont blow anything, plus, what do i do with the dimmer light wire for the deck? cas right now its not plugged in or anything or attached to anything,should it be? thanks for the help, i was completely clueless before.
  1. Keeps blowing fuse
    By OldSchoolSwap in forum 3geez Accords
    Last Post: 07-01-2011, 01:24 AM
  2. 70 amp fuse blowing
    By fraza in forum 3geez Accords
    Last Post: 07-30-2006, 07:04 AM
  3. Lights dont work
    By FyreDaug in forum 3geez Accords
    Last Post: 03-10-2006, 06:42 PM
  4. Tail light and instrument cluster lights out..HELP
    By rleyba in forum 3geez Accords
    Last Post: 01-12-2004, 06:50 AM
  5. Instrument Cluster Lights
    By factorVIII in forum 3geez Accords
    Last Post: 06-29-2003, 06:10 PM
