Results 1 to 23 of 23
Thread: Civic springs DO work
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Thumbs up Civic springs DO work
    This weekend i installed a set of coilovers i bought from a friend. They're for a 98 Civic EX. I've heard rumors that they work so i thought i'd try it since i got em for super cheap. They worked just fine! I'll update as i put more miles on em, but i've been driving around all weekend and they've been working great. The ride is a little bouncy, but not too bad and i like it. Besides, im not driving a 4x4 anymore which is a good thing.
    I have no idea what brand coilovers these are. All i know is that they are blue.
    I'm getting pictures of my car soon.
    Nothin' 2 Old Racing
    Mar 2004
    1993 Acura Integra B18A1
    Stockbridge Ga
    sweet. I wonder if stock civic springs are any lower than ours? Way tight b/c now we know there are tons of options for civics out there.
    "I'll head back to the neverland ranch with a peanut butter jelly chiken tuna sandwhich.."
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    damn damn damn! that made my day!
    nx: ill be placing that order on the 26th!
    I havent forgotten my roots
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    i want to make everybody aware that since the civic springs/coilovers are obviously NOT made for our car, there may be some issues that come up after an extended period of time, but only time will tell.
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    Quote Originally Posted by NXRacer
    let's hope there is nothing serious in long term status. Keep us updated.
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    did you have to adjust the camber/struts?
    Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
    Nov 2001
    huntsville, al
    when dropping a car EVER you need to adjust the camber! Coil-overs are very stiff and req some good struts!
    civic coilovers are meant to handle the weight of a civic which is close to an accord! No problems are possible.... springs are springs coilovers are coilovers!
    its not like using 4cyl mustang springs on a 5.0 car
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    the civic weight is pretty close and usually the spring rate is way to high for it anyway so the added weight of the accord helps control the coilovers a little. The ride is bouncy with the coilovers i'm using, but its not super harsh.
    And yeah, you deffinately need to get a camber kit. My wheels right now sit like / \ this instead of | |. the biggest issue you need to take care of is toe alignment. bad camber wont eat your tires nearly as much as bad toe will.
    LXi User Oyvind Ryeng's Avatar
    Mar 2004
    Tromsų/Norway
    Wow, this sounds great! Thanks for playing the role of guinea pig (sp?). Let us know how they work out. What struts are you using?
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    stock. im waiting to see how long it is until they blow
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Hmmm.... now if those work... I'm curious if something like a tein full coilover kit from a civic might fit? ... I know there may be some modification needed, but if so, I would so buy some of those.
    SEi User adams86lxi's Avatar
    86 Honda Accord LXI 5speed
    so cal.
    damn, thats good info to know i might have to get a pair of coilovers for a civic. Is it the 96-00 that work only or are their other civic generations that will work fine too? So you had no problem putting them in at all, no modifying or anything? And how low do you have yours set at? THANKS!
    http://www.myspace.com/3364524
    b20accord SN on honda-tech,homemadeturbo,clubcivic,turbod16, and many more
    Jan 2004
    Bucket
    Bay Area, CA
    super sick, i thoght the 3g teg might work, but no.
    3geez for life.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    no modification was done to install the CO's except i didnt use the top plate for them. The 96-00 coilovers will fit. As for other generations, there's only one way to tell.
    Nov 2001
    huntsville, al
    on some ebay auctions they list coilovers for 88-00 civics so one assumes their the same!
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    and you know what they say when you assume.........especially with eGay items.
    Jul 2004
    Did u used the rear & front coilovers of civic??
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Quote Originally Posted by mesdeir
    yes. i used a full set.
    Jul 2003
    93 civic
    San Francisco, CA
    I wonder what the spring rates on the coilovers you used were. I know alot of Integra DC4 Users use civic springs/coilovers for a softer ride since DC4 are a bit heavier than Civics. DC4 integras (3rd gen integ) LS are about the same weight as the sedan LXi give or take a 100lbs.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    well the spring rate is about perfect IMO because the ride is just bouncy/stiff enough to let you know they're doing their job, but not so much that they jolt the teeth out of your head.
    LX User 88accordlxcarb's Avatar
    Jan 2003
    '88 Accord LX(carb)/'92 Infiniti G20/'00 Infiniti I30/'88 Oldsmobile Cutlass Ciera(286,000 miles), 2004 VW Passat, Golf Cart...
    Middle Georgia
    Coilovers come with the struts(or shocks, i always get them comfused) in them right? SO we wont have to get revalved bilstiens, or will we?
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    i just used the sleeve coil-over shock setup. Just springs, no struts. The ideal setup is new struts that are made to handle the shorter springs.
    wprocomp's Avatar
    Armrest whore
    well if you can find some 88-91 prelude front struts they will work fine,I would think you would have a easier time finding konis for the lude,now the rear is the only problem,I havent found a match for that yet
  1. civic springs
    By CzEcHy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-29-2012, 10:54 PM
  2. Will civic springs fit
    By girlcrazy_4 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-25-2009, 11:09 AM
  3. would our springs fit in a 88 civic?
    By A18A in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-23-2006, 02:57 AM
  4. 96 civic- will it work?
    By geesnow in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-11-2005, 05:45 PM
  5. Will these springs work?
    By 89Hatchdx in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-18-2003, 12:39 PM
