Results 1 to 7 of 7
Thread: need help wont turn over!!
    So Cal, Orange Co.
    hey guys, i didnt mess with anything and my car wont turn over. I took the cover off the shifter and ebrake to paint it and i tried starting my car, but it wont turn over. It has done this b4 but it usually starts if i put it in neutral, but i did that and it wont turn. Im almost 100% sure its electrical. Please help asap i need myc ar by tonight. thanks. Oh yea, im auto 88 LX 4dr. I know someone will know what to do. please help
    Kevin
    So Cal, Orange Co.
    nvm, some mod delet this, my battery was dead, hooked a battery up that was in my garage and it started fine. thanks anyway. Guess listening to music wile working is bad.
    Kevin
    Aug 2004
    Check the neutral safety switch set it to neutral or jumper it and see if it starts. You may need to adjust or replace it.
    So Cal, Orange Co.
    actually i have another question, cause my car didnt start again and i had to jump it witht he battery again, it looks like theres alot of crap on the positive post of my cars battery, would that cause the non starting? if it can ill take the time to clean it with a wire brush. also, im about to run two 760 watt amps with my stereo, will that be abad for my battery? if its not starting now, is it going to be even workse? i just bough a new battery a couple of months ago. thanks for the help.
    Kevin
    k-roy's Avatar
    87 LX
    Yea that corrosion on the post is bad. Brush it off and get the inside of the cable connector while you are at it.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    If you're putting a huge system in like that, I'd suggest a higher output alternator. You can get yours re-wound or I think you can buy them.
    So Cal, Orange Co.
    yea, i think tomorow im going to clean the post off. As for the alt, im going to have to wait for money to find its way to me cause i dont have any right now. But i def know that im going to get a new alt in a while. thanks guys for your help.
    Kevin
  1. Help it wont turn over for awhile
    By va_nig_rawr in forum 3geez Accords
    Last Post: 09-22-2010, 10:11 AM
  2. Urgent: Key Wont Turn
    By Sporno in forum EFI Tech
    Last Post: 03-01-2006, 01:07 PM
  3. wtf, wont turn right??
    By 2drSE-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-29-2005, 08:32 PM
  4. Fan wont turn off
    By Scarface in forum 3geez Accords
    Last Post: 09-04-2003, 01:21 AM
  5. damn fan wont turn off... please help
    By ALTERED4 in forum 3geez Accords
    Last Post: 02-28-2003, 04:37 PM
