Results 1 to 4 of 4
Thread: 83 2nd Gen accord 1.6 problem...strange
    Jul 2002
    83 Accord
    I know this is quite an old car, but it run quite. Recently when i
    accelerate at certain speed (i tried transmission 2,3,4,5) and leave the
    clutch pedal and fuel pedal, (the gear is still on) some strange noise like
    "pop pop pop" will come out from my engine. Anyone know what problem is
    this?? gasket blown??... the sound come out everytime I do this, normally
    like I went down from hill, I put in gear 2 and let all pedal off, the
    sound is very obvious, it come out continuously.anyone know, please help.
    Thanks.
    Regards,
    Max.
    Is the sound out of the exshaust? If so it could be a diverter valve on manifold that takes in fresh air on declereration. I'm not to up on these cars but if it has a air pump take belt off and see if it helps.
    Jul 2002
    83 Accord
    i'm not sure where it came from, but obviously is from engine room... i'm not sure coz can't test where is the sound really came from.. (can't hang myself above the engine room while the car run). and which air pump you talking about??
    Thanks.
    Max.
    Backfire out of carb means you need a distribter cap rotor & plugs
    backfire out of exshaust pipe means a fautly pollution pump/devise usally or worse case senerio bad valve timing/valves/timing belt worn
  1. Strange problem on my 89 Accord
    By cbolyard in forum 3geez Accords
    Last Post: 01-25-2013, 05:14 AM
  2. strange electrical problem
    By lostforawhile in forum Carburetor Tech
    Last Post: 03-24-2007, 06:43 PM
  3. Strange but New Problem
    By smufguy in forum 3geez Accords
    Last Post: 01-24-2004, 06:37 PM
  4. Strange engine problem, does anyone know what it is?
    By KaMiKaZeE in forum 3geez Accords
    Last Post: 10-15-2003, 09:23 AM
  5. strange new problem
    By hondamanlxi in forum Interior & Exterior Care
    Last Post: 07-16-2003, 03:23 PM
