:uh: :rockon: :bow: :cool: :tongue: :jaw: I am almost too embrassed to mention what the final problem was....the right side connector on the coil was reversed, and I now know the hard way, causes the coil to put out a big fat ZERO spark. The upside is I became familiar with the four possible options the B20A can run:
stock wiring, teg dist and cyl sensor with stock ECU=Carot
stock wiring, dist = Adam and I
modified wiring with USDM Lude igniter, PK2 ECU=Gregg
JDM ECU and Dist=Garrett
The good news to all this is the Accord and Lude Vacuum Adv. Eng Harnesses and ECUs are close enough to use these methods for dropping the B20A in the 3Gen Accords(?) and Ludes
I am going to start collecting pics as I work through the issues of the alternator, shafts and power steering. Once working, I will review pics that apply to my lude and what worked on the accords. It is worthwhile for the Accord owners, because we already know the A20 is similar to the BT. Now, I just need to check the shafts on the 86 Lude A2K5 5Sp as I mix a 3Gen Lude shaft with my 86 Long to see what will work on the JDM B2K5 and JDM intermediate that came with my B20A.
More than two years, and I can safely say I am over the hump and I could not have done it without this site and all of your patience and help. I will continue to share my progress.
Chris
