Results 1 to 12 of 12
Thread: Fuel Injector Q?
    LX User Gregs89AccordLxi's Avatar
    1989 Honda Accord Lx-i Sedan
    High Desert, Southern California
    Fuel Injector Q?
    Hey guys i noticed that there is some gas around one of my injectors. i thought it was dirt and cleaned it off but a couple of days later it came back, usually when a fuel injector goes bad what are the symptoms?
    shepherd79's Avatar
    Falling Waters, WV USA
    i am not an EFI guy, but i can tell you right now it is O-rings on your injectors.
    1989 Accord LXi A/T
    umm, okay. but how do you fix it?
    2 of mine are leaking... seems kinda dangerous driving around with fuel leaking in the engine comparment...
    later !
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    You better take care of that asap! Or you'll be driving in flames down the road!!!
    Have the "O" rings replaced to seal it properly. Make sure that you inspect the injectors properly to make sure they are not cracked and leaking through there.
    You might end up replacing the bad injectors if the "O" rings don't fix the problem.
    http://vtecnos.tripod.com
    Member Since 7-9-01
    Nov 2000
    Here's the tip you need. It is NOT, NOT, NOT the o-rings. It is the injector itself developing a leak through the join between its plastic mand metal components. You will need to replace the leaky injectors.
    Best price factory injector: rceng.com. You will need to call them to order their "test" Honda injectors at $42.50 each.
    Best aftermarket price: nopi.com. Python Venom injectors for $39.95 each.
    You will be kicking yourself if you spend $50 for the seals and just find out (like I did five years ago) that it is not the seals. Save yourself the "learning experience" and replace the injectors. They come with the necessary rubber parts.
    BTW, the only oring that actually seals against liquid gas is the little one in the fuel rail. The other rubber parts are the top cushion and the seal with the intake manifold.
    Good luck!
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I have three leaky injectors. Is there any reason to replace them as a set or can I save the ~$40 and get only 3?
    Last I checked NOPI had Crown remanufactured Honda injectors for $30 each. A lot of Crown stuff has a lifetime warranty, but I wanted to check before picking them up.
    Thanks
    Mike
    88 Lxi/ 5spd
    Tennessee
    i have a set of four i replaced when i got high flow units....nothing wrong with them and they don't leak.....100k mile on them...i'll take 30 bucks for them.....you pay shipping
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    Nov 2000
    That's a good deal. The high flow injectors won't do much for you on an otherwise stock engine. I don't know if they will hurt fuel economy or not. Others may know that.
    you do not have to replace all of them. I replaced one about five years ago, one three years ago, and the last two earlier this year. I paid $90 each for the first two, though. Now that I know you can get them for $40 a pop I would just do them all to save the time, but it won't hurt just to replace the leaky ones if cashflow is the issue.
    Later!
    Miami, Florida
    Thanks
    If your replacing them with stock injectors, you can just replace the bad ones and save a few bucks.
    If your thinking of a performance injector, then replace all four.
    And YES performance injectors will burn fuel a bit faster, so if your cheap on fuel it is not a big diffrence but it will add up.
    Member Since 7-9-01
    I think there may be only 4 types of injecters used in the whole automotive industry(stock). This may sound cheap but I have used an entire intake complete with injectors sussesfully in past. But mine were leaking internaly not externaly like yours,engine was real hard to start and smelled of raw fuel in morning.Plus I heard them leaking from inside the intake pleum like a tire leak{hiss}
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    jteuton that's a great deal. I'll take 'em. Do you have paypal? My zip is 85716 for shipping calculating purposes. Let me know the total so I can get the money to you.
    Thanks
    Mike
    89 SE-i Coupe
    Lancaster, Ohio
    I agree with DBMaster...it is probably NOT the o-rings. Been there and done that. I would bet money on it being the injectors themselves. And if you buy new injectors you will get all the seals and o-rings.
    89 Accord SE-i Coupe
    89 Accord LX-i Coupe
  1. Any consensus on the best fuel injector?
    By w261w261 in forum EFI Tech
    Last Post: 04-27-2011, 08:25 AM
  2. Fuel Injector Help!
    By JDMPrelude23 in forum EFI Tech
    Last Post: 03-06-2011, 06:21 PM
  3. fuel injector problem help
    By petey882 in forum EFI Tech
    Last Post: 07-04-2009, 01:17 AM
  4. Fuel Injector Leak
    By bank2me in forum EFI Tech
    Last Post: 11-30-2008, 07:55 AM
  5. Fuel injector question
    By stat1K in forum EFI Tech
    Last Post: 07-04-2006, 03:25 PM
