Results 1 to 6 of 6
Thread: Failed smog: high NO
    Feb 2004
    89 accord lxi
    down by the bay
    I've got an '88dx that I drive around when I'm working on the lxi. I figured I should register it since it got towed once already, but when it came time to get it smogged I failed because my NO was 1100 out of an allowable 850. So...what causes high NO? And what things can I do to help my car pass (besides usual tune-up stuff)?
    May 2003
    88 Accord LX 88 Accord LXi
    A few things can cause high NOx. The major items are EGR or catalytic converter.
    Feb 2004
    89 accord lxi
    down by the bay
    Fahck. I'm going to try kicking the car a few times and see if that helps.
    10/Honda/Ridgeline
    NJ
    a couple of things can cause high NOX and the Catalytic converter is not one of them.
    1. your ignition timing is advanced too much
    2. you are running lean
    3. your egr is not working properly.
    To fix this situation.
    I would say, get new plugs (NGK V-power) and set ur ignition timing a lil back. As in retard ur ingnition a couple of degrees back.
    Get yourself a can of EMISSION PASS stuff from walmart, Slick 50 makes one and Guaranteed to pass emissions, is another. Get either of those bottles (about 7 bux) pour it in and then take ur car to the inspection and i would say ur car would defenitely pass.
    Feb 2004
    89 accord lxi
    down by the bay
    Thanks for the advice smufguy, I had forgot about that emission pass stuff. Kind of like the automotive equivilent of trying to pass a drug test
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by Strugglebucket
    hehe, yeah its a high concentrate/strong fuel system cleaner and nothing else. Just better than the regular fuel system cleaner thats it.
  1. car failed smog NEED HELP
    By Roknboker in forum 3geez Accords
    Last Post: 04-18-2009, 06:44 PM
  2. Failed Smog test
    By michigan_accord in forum 3geez Accords
    Last Post: 07-02-2007, 08:05 PM
  3. failed a smog test...
    By snoopyloopy in forum 3geez Accords
    Last Post: 05-11-2007, 11:37 PM
  4. Failed smog
    By TheKevin in forum EFI Tech
    Last Post: 12-25-2006, 09:34 PM
  5. Failed smog check....
    By isadisa in forum EFI Tech
    Last Post: 02-04-2003, 11:31 AM
