Results 1 to 5 of 5
Thread: Does the ECU lie??
    LXi User Chrome_thangs's Avatar
    1989 Honda Accord LXi Coupe
    That dirty south!! Columbus Ga.
    Does the ECU lie??
    My ecu was blinking a code of 6-the ECT Sensor. Before i went to go buy the part i checked it again and it's not blinking. My ecu is connect correctly because when you turn the key i get a single blink.
    Should i still replace my ect sensor? Or was the ecu "mistaken"
    the ecu flashes only what it sees, so if you got that code only once it could have been a temporary malfunction
    burgundy 86 honda accord/ brown 89 chevy caprice wagon
    i would do a wiggle test and check wiring.most likely you have an intermitent open short.
    88 Lxi/ 5spd
    Tennessee
    how can it be an open short?.....i thought it had to be one or the other
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    open short= no connection
