Page 5 of 13 FirstFirst 123456789 ... LastLast
Results 101 to 125 of 315
Thread: other ECM options
  1. #101
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    The guys on PGM-FI.org said that the knock detection in Honda ECUs wasn't so great..
    Yeah Ive been reading up on that over there. They also say it malfunctions with forged internals and is of no use for boost. Which is y I wanted it in the first place so I guess no need for it now.
    Just a obd-1 ecu and a dist that will fit.
    Now the question is which ecu will be best suited for the a20?
  2. #102
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Houston, Texas (Home of the Quicksilver project)
    Darryl (from Openloop Motorsports) ended up with the F-22 distrubutor as about the only one that would fit. Even then, it still needed a bit of modification in the form of a small bracket. I emailed the guys at Distributor King and gave them a pic of our distributor for a match, and they came back with the same thing; the F-22. Seems like this is the best match (fitment wise) there is. They are two types; TEC-TD31U (internal coil, 90-91 Accord) and TEC-TD52U (external coil, 92-93 Accord).
    "Feed their greed with your need for speed"
  3. #103
    guaynabo89's Avatar
    FL
    What exactly did you ask these people? You sent them a pic of the a20 dist?
  4. #104
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Yeah, I sent them pics and measurements of my dizzy, and asked them for their opinion on what would be the closest match in a Honda obd-1 distributor.
  5. #105
    guaynabo89's Avatar
    FL
    I thought the 4th gen Accords were still obd-0? or maybe just from 92 and on are obd-1. I've got to look at my 4th gen to find out.
  6. #106
    carotman's Avatar
    Montreal South Shore
    The speed sensor modification might be problematic for the cruise control. We may need to use a diode not to interfere with the cruise signal. I'm at work not so I'll check the wiring diagram tomorrow and see if it is actually a problem.
    guaynabo89, the Accord were OBD-1 since 1990. I suggest everyone to use a 92-93 external coil distributor since the A20A already has the coil mounted externaly. this inveoles less wiring and reliability issues
    I need these parts!
  7. #107
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    why would we need to modify the speed sensor if we already have one? don't we just need to hook up our speed sensor wire to the p75(or whatever ecu we choose) pin for it's speed sensor? or are they different..?
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
  8. #108
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    I would not think so. You should be able to just use the P-75 pins like you say.
  9. #109
    maka_RTH's Avatar
    Nov 2001
    Orem, Utah
    Quote Originally Posted by Gregg86DX
    Here is a link to some more pin-out lists:
    http://www.g2ic.com/tegtips/engine/15.html
    There is a link on there to a spreadsheet with several ECU's, including the P72 and PR4. The PR4 should be the same as a P75 (they are both OBD1 LS Integra ECU's). If you compare the P72 and PR4, you can see they are almost exactly the same.
    i added in our ECU pinout for easier comparison of what's already there and what would need to be added. i used the pinout for the '89 ecu.
    http://www.maka-rth.com/ECU%20pinout...s plus PJ0.xls
    Greg
  10. #110
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Nice. Why is the P-75 pinout so elusive? I cannot find it anywhere. By the way, Greg, you working nights or what?
  11. #111
    Justin86's Avatar
    Medford, Oregon
    Quote Originally Posted by Robs89LXi
    Well most of the OBD-1 ECU's are pretty mush similar unlike the OBD-0's. AS far as I have seen the P-75, P-72, P06 are all the same just for the VTEC stuff.
  12. #112
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    For those of you that don't know what OBD years are here they are.
    OBD 1 = All Vehicles from 1990-1996
    OBD 2 = All Vehicles from 1996-Present Year
  13. #113
    Vinny's Avatar
    Aug 2003
    Here, not there
    Quote Originally Posted by Justin86
    Correct. Most of the pinouts are the same. As a general reference dfor OBD1 ECU's
    A1-INJ1 INJ1
    A2-INJ4 INJ4
    A3-INJ2 INJ2
    A4-VTS VTEC solenoid
    A5-INJ3 INJ3
    A6-PO2SHTC O2 sensor (heating element)
    A7-FLR1 fuel pump
    A8-empty
    A9-IACV IAC valve
    A10-empty
    A11-empty
    A12-FANC engine coolant temp switch
    A13-MIL MIL (check engine light)
    A14-empty
    A15-ACC (a/c compressor clutch)
    A16-ALT C alternator
    A17-IAB IAB Solenoid
    A18-empty
    A19-**
    A20-PCS EVAP purge control solenoid
    A21-ICM ICM
    A22- *per Sander* Ignitor
    A23-PG1 ground
    A24-PG2 ground
    A25-IGP2 to main relay and to gound for o
    A26-LG1 gound
    B1-IGP2 to pin A25
    B2-LG2 ground to shields for CYP & TDC
    B3-**
    B4-**
    B5-ACS a/c switch
    B6-empty
    B7-**
    B8-PSPSW PSP switch
    B9-STARTER SIGNAL starter signal
    B10-VSS vehicle speed sensor
    B11-CYP P CYP -P
    B12-CYP M CYP -M
    B13-TDC P TDC -P
    B14-TDC M TDC -M
    B15-CKP P CKP -P
    B16-CKP M CKP -M
    D1-VBU Back Up Power
    D2-BKSW brake switch
    D3-KS Knock Sensor
    D4-SCS service check connector
    D5-empty
    D6-VTM VTEC pressure switch
    D7-TXD/RXD (data link connector)
    D8-empty
    D9-ALT F alternator
    D10-ELD electric load detector
    D11-TPS TPS Signal
    D12-**
    D13-ECT ECT sensor
    D14-PHO2S O2 sensor
    D15-IAT IAT sensor
    D16-VREF VREF
    D17-MAP Map Signal
    D18-**
    C19-VCC1 MAP 5V
    C20-VCC2 TPS 5V
    C21-SG1 MAP GND
    C22-SG2 TPS GND
    My contribution to the thread. Some people dont feel like following links and stuff and dont want to have to PM people for info so I'll post some here.
    Enjoy
  14. #114
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    good stuff vin. i think we've hit on something really good here. Maybe it should be moved to project central as a sticky???
    Nothin' 2 Old Racing
  15. #115
    guaynabo89's Avatar
    FL
    Quote Originally Posted by NXRacer
    good stuff vin. i think we've hit on something really good here. ??
    It definately is.
    One things for certain. I'm going to dyno my car before and after attemting the obd-1 conversion to see if there is any whp diff, and compare the hp and tq graphs to see if there was any improvements across the rpm band between the two setups.
    WHich I think there should be nothing but improvements compared to the accord fi setup.
  16. #116
    10/Honda/Ridgeline
    NJ
    That is awsome fellas. You guys are fucking crazy. hehe, seems like openloop had made a great way for u guys to explore new territories. Now you guys can say, Who said my ecu dont control ignition??
  17. #117
    Vinny's Avatar
    Aug 2003
    Here, not there
    Someone mentioned knock sensors earlier. On the back side of the block theres a plug/Bolt just to the right and up from the oil filter housing. I'll try and posy a pic of the location later to show everyone. I'm not sure if it goes into a waterjacket or what but I'll find out when I pull it off, if I can get it off. Connect to D3 of the ECU harness plug and tadaaa
  18. #118
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    wouldnt you want to tap a hole higher up on the block that at the oil filter housing?? I'd want it as close to where the knock would be coming from i imagine. . . . .
  19. #119
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    hey i was looking for some wiring fiagrams for this AFC i got from Sheph and came accross this: http://www.apexi-usa.com/productdocu..._safc_wire.pdf
    it was a bunch wiring diagrams for a few diff vehicals. i wasnt sure if it would help or not.
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
  20. #120
    Vinny's Avatar
    Aug 2003
    Here, not there
    Just up from the filter housing is about as High as you get, for the most part. A few inches higher and your in the head
  21. #121
    carotman's Avatar
    Once this thread goes too big, we'll have to gather all the information on a same page.
    Regarding the speed sensor, the OBD-1 ECU is looking for a 12V quare Wave while the OBD-0 is looking for a ground...
    Anyway, I posted the link for the modification needed. I just didn't have time to look into the cruise control thing.
    I need these parts!
  22. #122
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    is the speed sensor only for the cruise control? cause i bet most poeple who are gonna be using this will have jerked out the CC a long time ago.
  23. #123
    Vinny's Avatar
    Aug 2003
    Here, not there
    I believe, and someone will correct me if I am wrong, that the speedo's on the 4th gens and up were electronic rather than cable driven. I think the sensor off the 4th gen tranny's only have a plug and no cable. Or so I have been told
  24. #124
    carotman's Avatar
    The speed sensor is used by the ECU for a number of things... you cannot avoid using it...
    I need these parts!
  25. #125
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    How would we convert to an electronic sensor... I don't want to use the cable, not do i want to use a cable driven speedo.
  1. What are my options?
    By SettleMoore in forum Classic Honda Community Chat
    Last Post: 02-21-2011, 11:17 PM
  2. Options
    By Jade in forum Interior & Exterior Care
    Last Post: 11-12-2003, 09:44 PM
  3. Options
    By Jade in forum Classic Honda Pics & Videos
    Last Post: 11-12-2003, 09:25 PM
  4. other options for efi !
    By Sean in forum Performance
    Last Post: 07-06-2002, 09:43 PM
  5. What are my options
    By 3rdGenMartyr in forum General Engine Swaps
    Last Post: 06-11-2002, 12:58 PM
VigLink badge
