So i've been thinking, since Seans setup is no longer an option i've been thinking about what else we could use to control timing and fuel for turbo and other high performance setups. Although that apparently was a good setup, there are a lot of other options out there for cheaper. A LOT of people have been using Uberdata and Hondata for a long time and from everybody i've seen/heard using it, they've had pretty good results. Lots of people are using it now to turbo the F22's which is a pretty similar engine to ours. (~2liter, SOHC etc etc).
My biggest problem i have right now is trying to find the code so i can import it to Uber/Hondata. I think that if i could get this, i have a few people i know that are really good with tuning in uberdata and hondata and i could probably get a good setup up and working. The best thing is that all you have to do is buy a blank chip and a chipable ecu (civics would plug right in to our wiring harness) and away you go. All you need is to know/find somebody who has a burner. I know of a couple people that will burn a chip for you and send it back ready to go.
I know that AEM and a couple other companies have stand alone systems that you can wire up, but i know for a fact that most members here can't afford $1500 for an ECM system and those that do probably wouldnt mind paying a small fraction of that price for a system that works (from what i've heard) just as good.
discuss
