Results 1 to 8 of 8
Thread: how do I know if my mounts are shot
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    Question how do I know if my mounts are shot
    OK, lately my car has been acting real real strange, especially in the front end. How can I tell if my motor mounts are shot? I have a strange suspicion that they are.
    -Mark D.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I'm curious about this too. All the other rubber and plastic pieces on my car seem to be shot. I wonder if my mounts are bad too. A few months of reaching 150 F daily for 13 years will do that to a car.
    Mike
    GDGuy11B's Avatar
    Jul 2001
    1989 Accord LX-i, 00 Civic EX
    Back from Baghdad (Tallahassee)
    one way to check is to have someone look at your engine when you rev it. if it jerks around and looks like something is wrong, then you should prolly get it checked...
    89 Silverstone Metallic LXi, custom Air Intake, DC Sports 4-2-1 header, A'PEXi N1 exhaust with 2.25" pipe, ACT clutch, Xenon body kit
    3geez member since July 11, 2001
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    Inspect each mount visually and check for cracks.
    Exesive vibrations are also a hint.
    Open the hood and apply the rear parking brake:
    Try this test in both, Reverse and 1st gear:
    -put the car in gear
    -slowly girk the gas a bit. Do not stomp on it! This could be dangerous!
    -If the engine jumps up and drops donw, you have a bad front or rear mount.
    Althouth some of you should NOT do this. Have a proffesional do it. I wouldn't want anyone to get hurt.
    http://vtecnos.tripod.com
    Member Since 7-9-01
    Nov 2000
    Yeah, due to the fact that Honda uses several different mounts on tops and bottom it is hard to see the movement of the engine to tell if the mounts are broken. You can see the motor between the hood and the body when the hood is open. That way you can hold the brake down while you give it gas (auto) or slowly let the clutch out a little.
    Take my advice, though. Just go ahead and replace the front and rear lower mounts. I think you are probably looking at $60-70 total for both. If they are not broken they are pretty well worn out. I did not seem to need to replace any of my upper mounts, or the one by the timing belt cover. It made a HUGE difference in the amount of idle vibration. It also helps to loosen all the mounts when you are done and tighten them in the sequence shown in the shop manual.
    Good luck with it.
    LXi User 89AccordLXI666's Avatar
    1989/Honda/Accord SE-i FI 5speed Coupe
    Hudson Mass
    What can happen if you don't replace them? Stupid question but just wondering.... I think I have to replace the two in the front.. Thanx Guy's
    I will alwayz drive my 3rd gen Accord, ya'll will neva c me driving a 4 door Ford.. lol
    Miami, Florida
    It will create a domino "effect" and shit will start breaking.... axles, chassis cracks, vibrations, ruff idle, bangs every time you rev in any gear and so on.....
    Member Since 7-9-01
    When I changed a engine on my 1988 dx I noticed that the engine mounts were perfectly placed in relation to weight of engine/trans. You could pivot the engine/trans. The mounts are not just solid rubber either kinda like a turnbuckle so I think dealer bought ones is the only way to go.
  1. raditor shot
    By xxxfrankensteinxxx in forum 3geez Accords
    Last Post: 09-23-2008, 08:57 PM
  2. motor mounts/tranny mounts
    By powderkey2 in forum 3geez Accords
    Last Post: 09-12-2006, 08:34 AM
  3. Oil pump shot, I think
    By Mac in forum 3geez Accords
    Last Post: 04-24-2004, 04:54 PM
  4. 300 shot of NOS
    By Justin86 in forum Performance
    Last Post: 05-03-2003, 04:11 PM
  5. My shocks are shot... Need help!!
    By HondaManDan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-09-2002, 02:39 AM
