because of all the OIL my car leaks. =( And it's coming right out of the drain plug, too. I've tried both a new plug (it would tighten up to a point then release again)and a self-tapping plug one size larger (had a mechanic install it so I wouldn't mess it up). I have to add about 2 quarts every time I stop for longer then a street light. I'm fresh out of ideas, maybe somebody else has one or two they can throw out here? I'm desperate enough to just think about welding the plug hole shut and removing the pan when I need to change the oil. =(
BTW, I think the problem with my drain plug is from my lowered car bottoming out and scraping. The self-tapping plug I had installed while I was in Texas, and it didn't start leaking till about 3 weeks ago, and it just recently got even worse.
