Results 1 to 7 of 7
Thread: Brake locking up a bit.
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    I have never had this prob. till I put my new brake light switch on, and even now it only happens everyonce inwhile. I will driving along doing about 60 only the RPMs will alot higher then they should be and it feels like something is holding back the motor, also the brake pedal gets extremly hard like I can just berly put my foot on it and it feels like the calipers are complelty pressed, also my rotors are warped which is why my car shakes a little when ever I put on the brakes but when the brakes feel really hard and I put them on to stop the car will shake so badly that my cd player will skip! Im going to bleed the brakes out later tonght when it cools down a bit but coul that be the prob.¿ I would say when they get hard it only takes about 1/4 of a inch for them to start shaking the car around. Oh two more things about this, I popped the hood after it did it, and there was brake fluid all over the inside of the hood, and you can smell something shorting out.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    brake fluid in the engine bay? could you tell where it was coming from? it sounds like a bad caliper or two untill you said brake fluid in the engine bay. is it coming out the fill cap or is there a break like leaking? if you are losing fluid you should lose peddal too.
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    '85 lude
    houston
    ......... check the vacuum supply to the booster
    1992 Acura Integra
    Kansas
    Thanx guys, the brake fluid looked like it came form the resourvior all the fluid was right above where it sits. The pedal isn't sfot at all, it is acually to touchy, there isn't any play in it at all.
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    ya know that happened to me one time, i screwed the damn lid on wrong and the fluid spilled out.
    i thought my booster was going out also. lol !
    ****** 1994 nissan maxima SE ******
    1992 Acura Integra
    Kansas
    that could be why there was brake fluid on mine, I did have to tighten it up, but I still can't explain why the pedal gets so hard to push.
    Dec 2003
    Austin, Texas
    bleed your brakes and make sure the cap is on right, and also make sure there isnt anything wrong with the cap. top the brake fluid off and they tell us what happens then.
    Car Pics
    vBGarage
  1. Rear brake locking up
    By Whitehonda in forum 3geez Accords
    Last Post: 02-05-2008, 08:31 AM
  2. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  3. Brakes locking on
    By Orion in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-28-2004, 11:12 PM
  4. locking mechanism
    By 86accordhatchback in forum Interior & Exterior Care
    Last Post: 07-08-2003, 10:18 PM
