87 lxi, severly beten 150k on it, code 12, during slow acceleration (uphill) or cruising, checked the egr valve, works, checked the lift sensor and compared it to another egr valve I had, matched, checked the harness to the sensor, a 5 volt, a ground, and a ground with resistance, checked the solinoid, it clicks, checked the wiring harness, 12v at the dark wire, ground with resistance at the red one, i re-routed the vacuum lines to spec, and replaced the cvc (green and white thing) it has vacuum at the side port when the center is plugged in, also, the air chaimber in my e-box has an extra port than the one listed in the e-box routing pic I found on this website (from the shop manuel) and i dont know what hooks up to this 3 rd port, (right now its #17 into the intake before TB, i appricate the help thanks -Shawn M.
