Results 1 to 8 of 8
Thread: need help with swap
    LX User 87AccordLXsdn's Avatar
    Feb 2003
    87 LX
    Savannah
    need help with swap
    im in the process of taking everything out of another accord to swap my car to a 5 speed. i was just takin the pedals out and i realized, how am i supposed to wire up the clutch switch?? i might of missed it in the how to or just not understood it. i could really use some help on this and any other wire issue i might come across.
    10/Honda/Ridgeline
    NJ
    this is in the wrong section, should be in technical.
    Anyways. so ur converting to a 5spd ? you need a 5spd pedal set. you dont really need a clutch switch, mine works without out. I dont know what u changed and what u did not, like the wiring harness and stuff. If u used a 5spd wiring harness (the cabin wiring harness) and it did not have a clutch switch wire, then dont worry. Ur car will start up fine. But again, need more info on what exactly u did so far.
    '85 lude
    houston
    clutch switches are for stupid ppl
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Don't worry about the switch. No need to wire it up.
    Feb 2003
    87 LX
    Savannah
    ok so i dont need the switch but is there anyway that i can cut down the brake pedal in my auto to be the size of a 5 speed?? and when you unbolt the pedals, how does the clutch cable come out?? cuz i looked at the pedals on my auto and they have a hole for the clutch switch so im wondering if the clutch pedal will just bolt up to that somehow?? i didnt check to see if it had a hole for the clutch cable to go through or not tho.
    Vanilla Sky's Avatar
    1999 Penalty Box
    you're better off buying the whole pedal set, as opposed to just the clutch pedal... and i wouldn't worry about the clutch switch, either, as these cars start normally without even pushing the clutch in on vehicles equipped with the 5spd as standard equipment...
    Feb 2003
    87 LX
    Savannah
    well i have a whole other car sittin in my garage but the pedals are just a bitch to take out. there's one nut that i cant reach at all thats makin me mad
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by 87AccordLXsdn
    do what i did with Jim's (hostilejava's car) drop the steering colum. Only four 12mm bolts hold this thing in and one adjuster (12mm i think) drop it and u will gain access to the one 12mm bolt on the pedal u cant reach. I took the whole steering out for Jim cause it was just too awkward and we were up for straight 10 hours and i was up for 20 hours non-stop so i just had to cut corners and not bust my back.
    If u wanna pull the whole steering colum (with the wheel out) get the 10mm bolt on the spline end of the steering column under the removable black cover on the floor pan under the carpet.
  1. b20a swap what parts do i need to complete the swap
    By freitos in forum JDM B18A / B20A Swap Tech
    Last Post: 02-10-2012, 06:21 PM
  2. need help with swap
    By 87AccordLXsdn in forum Classic Honda Community Chat
    Last Post: 09-15-2004, 04:46 PM
  3. Swap for an 88 LX?
    By Dennis in forum General Engine Swaps
    Last Post: 01-07-2004, 08:21 PM
  4. Now that the swap is done.....
    By Tref_LXI in forum Interior & Exterior Care
    Last Post: 04-13-2003, 04:30 AM
  5. b 18 swap
    By madmod89lxi in forum Performance
    Last Post: 10-02-2002, 12:17 PM
