I will double check that if i dont see the problem with the head off but we did check the TDC with the cam timing and it was fine. But the leak down test dont lie when the cams are out all the valves should be closed and unless the headgasket blew which i wish was the case im still doubfull since the compressed air blew out the inlet filter for the turbo.
I wish i had a bad injector! LOL
