I'm finnally done putting my conversion to efi , but I'm not getting any power to fuel pump ? I've checked there is power at fuse box under the dash but not at the pump. I'm I maybe missing something in the conversion, isn't there somekinda relay for the pump that tells it when the engine is running, so it doesn't pump when the engine has died or is turned off. Or does the compter control that and is there something that possible need to be reset on the cpu ?
Any ideas ? thanx !![]()
