Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 153
Thread: QUAD Motorcycle Carbs
  1. #76
    Jul 2003
    88 Accord LX
    Portland, OR
    Re: my accord has quad carbs
    so a little update... two of the carbs weren't working right and the vacuum control pistons weren't opening all the way. So i got that fixed and can now say that i like these carbs a lot better than the weber. There is equal if not more power. Definitely some more torque through the mid range. And power delivery is very smooth. It also drives more like and efi car where you can just mash the gas and it doesn't hesitate or anything. So now i just need to figure out an air filter and do a little clean up on the manifold and the project will be done.
    Ok for anyone thinking of doin this..... make sure you realize the extent of what you are doin.... It took me a good couple weeks of working on it fairly regularly to get the car to start on its own and actually be drivable. This is not a mod for the amatuer mechanic or someone who has never tuned a carburetor before. However for those who feel they can undertake it i think it is very worth while. But a time slip and a dyno this summer will show me how worth while.
    Zeph Uusitalo
    Proof That Bike Carbs Work On An A20!
    Dyno'd the accord. It made 104HP 117TQ.... And blew smoke everywhere. I guess the 210K motor really is done
  2. #77
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    you need a baseline with your weber now though.
  3. #78
    Jul 2003
    88 Accord LX
    Portland, OR
    didn't someone baseline an accord quite a while ago stock... and see like 85 whp's. But you are right a comparison between a weber and these would be cool... Maybe if i feel really motivated this summer! And rich!!!! that takes a bit of dyno time to compare both
    Zeph Uusitalo
  4. #79
    Quote Originally Posted by Zufer
    are your carbs slide carbs or based on the variable venturi(su) design? a lot of the japanese bike manufacturers abondoned the old slide carb design for the su design carb on bikes. they offer much better mixture control and better driveability at low rpms. the two designs look the same,but on a slide carb the throttle directly controls the piston,but on the variable venturi design the piston is controlled by airflow through the throttle bore and the throtle has no direct connection to it. how it works is that the top of the piston has a passage to vacccume in the throttle bore,when the throtle plates open,this vaccume causes a low pressure area above the piston,causing it to rise,this exposes the metering needle and allows more fuel to enter the throttle bore. when the vaccume stabilizes the piston comes back down lowering the needle and allowing less fuel to enter the bore. it's very simple and is very accurate. the SU carbs were the original carb to do this,and the design was copied many times over the years. a lot of these copies were on bikes. primarily because it worked so well and it was extremly simple.
  5. #80
    Jul 2003
    88 Accord LX
    Portland, OR
    yes they are the variable venturi type. What part of my comment was that a response to?
    Zeph Uusitalo
  6. #81
    oh you said they hadn't been working right,I was just wondering what kind of carbs you had been using,I am doing a project sort of like this right now also,it's interesting to compare the different carb projects going on. who needs fuel injection? LOL.
  7. #82
    i do...but is still got carb love as long as it runs right
    LX User teck's Avatar
    Dec 2006
    1995 Civic DX
    ulster county new york
    sexy!. you pulled those off an older model CBR didnt you?? my friend has an 80s CBR and the cards are exactly the same
  9. #84
    Jul 2003
    88 Accord LX
    Portland, OR
    I believe they are off a 1986 shadow, but i got them from a guy on ebay so i don't know for sure
    Zeph Uusitalo
  10. #85
    Dec 2006
    1995 Civic DX
    ahh
  11. #86
    Jul 2003
    88 Accord LX
    Portland, OR
    My new intake setup, Final 4 carb setup
    Enjoy, comments are welcome.
    Zeph Uusitalo
  12. #87
    Re: My new intake setup, Final 4 carb setup
    very nice.
    wprocomp's Avatar
    Armrest whore
    your cars about to ambushed by the grass lol
  14. #89
    LXi User 87lxiaccord's Avatar
    1987 honda accord
    st.pete
    Does it run? Where'd you get that strut bar?
    <3 sohc
  15. #90
    Are you running the stock fuel pump to handle those? Anyways vids!!
  16. #91
    snoopyloopy's Avatar
    Killa Cali
    hothothot. that's pure sex right there. how does it run? any power numbers, or at least estimates?
  17. #92
    Jul 2003
    88 Accord LX
    Portland, OR
    it runs, still needs a little bit of tuning, but runs amazing, yep stock fuel pump. As far as power, well it was noticably better than a really well tuned weber 32/36. And it is extremely smooth power.
    and the strut bar is a shucks civic bar that i redrilled the holes on and flattened out the bends in the bar
    Zeph Uusitalo
  18. #93
    That is awsome dude, and I bet tuning 4 different carbs is a bitch .
  19. #94
    thats sexy
  20. #95
    Feb 2007
    88 DX Hatchie
    wow nice. i say for future reference turn down the white balance there's a bit of overexposer making the picture washed out. sorry a bit of my photography kicking in. love the carbs man
    "The Original White" 88 DX Hatchback
    Mysterious Project Car
    www.myspace.com/tunerplayground
    You won't know what hit you
  21. #96
    looks pretty cool. would it be possible for you to make some sort of video? i'd love to see a vid under the hood and then while driving.
  22. #97
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    good work looks really nice.
    I have one question though.... Why not leave them individual and run some trumpets with foam filters on them instead of tying it into that plenum? Did you make tha too?
  23. #98
    I was thinking the same thing at first, but couldn't word it correctly.
  24. #99
    LX User skycam_313's Avatar
    Dec 2006
    88 DX Coupe
    hayward, CA
    NICE.
    mods:
    stage 4 vacuum removal
  25. #100
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Cool.
    CARDONE SUCKS.
  1. Motorcycle Carbs on a CVCC engine?
    By SylusMk2 in forum 1geez Tech & Performance
    Last Post: 09-01-2012, 07:03 AM
  2. Quad ignition coil?
    By FyreDaug in forum Performance
    Last Post: 06-17-2006, 07:41 PM
  3. Anyone wanna buy a Motorcycle?
    By TJ89Accord in forum Trading Post
    Last Post: 10-11-2003, 09:11 PM
  4. motorcycle carbs...return line?
    By sixgears in forum Carburetor Tech
    Last Post: 07-31-2003, 05:32 AM
  5. Quad T/B
    By 2Fast_Fiero in forum Performance
    Last Post: 08-25-2002, 12:02 PM
