With my new B20A swap, I didn't like the way the clutch cable goes in the enginebay. It rubbed against the valve cover and the angle was far from optimal on the transmission bracket.
I decided to try a 90-93 Integra clutch cable and see how it fits. (got it for 15 bucks at the junkyard)
So far the fitting is alot better. Also, it is routed above the intake manifold just like the EFI speedo cable. It leaves more room for Turbo guys and un crowds the front on the enginebay.
The fitting is great except that the adjustment bolt on the transmission is almost at the maximum. some washers would solve the problem I guess.
The rubber seal on the firewall is bigger on the integra so I will have to work out something but so far I like how it fits.
I will take pictures soon.
