Results 1 to 4 of 4
Thread: knocking turning right
    86 accord dx hatchback
    johnstown pa
    Question knocking turning right
    well jus got the damn thing runnin again...... new problem..... never noticed this before when i had it runnin but after i tore everything apart put it back together and got it on the road again.. i noticed a knockin sound when i turn my car to the right.... could i have put something on wrong or lose???? or is it my cv joint goin bad.... i never feel it wobble till i use my breaks..but my rotors calipers and brake pads r all new on the front im at a loss....if its the cv joint i can get one off a friend u had an 87 lxi..... can i use that on my 86 dx? thanx
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    sounds like your CV joint is bad. The 87 lxi axle should work as long as its the same type of transmission that you have.
    Nothin' 2 Old Racing
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I would agree on bad cv joint too. In some cases, you can grab the drive axle and jerk on it to see if there is any play in it (around the cv joint). If there is, your cv joint is going out.
    Blkblurr's Avatar
    Dayton, Ohio
    My cv joint made the same sound when it went bad.
  1. Knocking
    By -$MOKIN- in forum 3geez Accords
    Last Post: 04-23-2011, 07:27 PM
  2. Motor is knocking
    By neo_blue_accord in forum 3geez Accords
    Last Post: 06-10-2009, 01:48 AM
  3. how do i know for sure if i have a rod knocking...?
    By Dennis in forum 3geez Accords
    Last Post: 05-13-2004, 01:36 PM
  4. knocking?
    By civdx94 in forum 3geez Accords
    Last Post: 02-01-2004, 07:12 PM
  5. Knocking sound when turning right....
    By krott5333 in forum 3geez Accords
    Last Post: 06-05-2003, 03:17 AM
