Results 1 to 9 of 9
Thread: EFI Vacuum Diagram
    Jul 2004
    EFI Vacuum Diagram
    Hey, does anyone know where i can find a vacuum diagram for the 86-87 efi?? I am in the process of an EFI swap and im scratching my head over what goes where...I heard the diagram is on the hood of the cars so i went to the junkyard and found an 87 lxi and tried takin the sticker but no luck with that, those things are like welded on...Anyways, if you guys know of anywhere that may have a diagram, it will be very helpful...I don't wanna get this all done and watch my fuel guage drop a mile a minute cuz i forgot the fuel pressure regulator vacuum line....mmmmmmmmmm 40 psi of fuel, haha
    if junkyards didn't exist, neither would my car...
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Use the Honda manual. It's available in pdf format and is linked in a sticky on the forum somewhere.
    Link to my 3geez garage
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    The EFI fuel pressure is 37 psi so 40 wouldn't be too bad.
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    IF you just need to get it running, just connect the MAP sensor to the throttle body on the pipe sticking out closest to the adjustment screw - it is really all the car needs to run. After that, work on the rest.
    87 LXi Hatch (5-speed)
    Riverside, CA
    is there a way of removing the vacuum lines on the EFI like the carb guys can?
    Jul 2004
    i checked the online shop manual, and same problem, its the vacuum diagram for the newer manifold and doesn't help me much, all i figured out was the fuel pressure regulator, any other ideas
    here is 86-87 EFi vacuum layout.
    you may want to save this one since you don't have real Shop manual.
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    While sort of on the subject of shop manuals: has anyone found differences in our cars and the Pauls shop manual? I mean, isn't his for the European Accords, and are there differences that anyone has found?
    Jul 2004
    thanks shep, you saved me a lot of searching and high pitch vacuum leaks, can't wait to get this whole swap done, ill get some pics on here when its all taken care of, i have my whole intake manifold done, i just need the egr valve, ill take some pics of the manifold
  1. NON US vacuum line diagram.
    By shepherd79 in forum Carburetor Tech
    Last Post: 06-13-2016, 06:16 PM
  2. 82-83 Accord Vacuum Diagram
    By ekoms in forum 2geez Tech & Performance
    Last Post: 05-10-2010, 12:16 PM
  3. B20A1 Vacuum Diagram
    By Slammed-Accord in forum 3geez Accords
    Last Post: 05-05-2010, 01:11 PM
  4. 84-85 Accord Vacuum Diagram
    By 2ndGenGuy in forum 2geez Tech & Performance
    Last Post: 07-16-2009, 05:09 AM
  5. Need Vacuum Hose Diagram
    By acessence in forum Classic Honda Community Chat
    Last Post: 07-17-2005, 02:43 PM
