Hi, I noticed a leak of what I think is power steering fluid because I noticed it when I was trying to bleed the power steering fluid because I refilled it a little bit. This leak is not really notorious unless that you try to bleed the system. I looked under the car and it looks like is coming from whatever is inside of a small square cover. I was reading on the service manual and it could be the steering gear? Is The Gearbox the same that Steering Gear? Both of them use power steering fluid? The leak is not really a big deal but in the reservoir is always under the low fluid leve. Do you know how important is the power steering fluid in that area where is leaking? What do you think that is wrong?Thanks in advance!Adrian.
