Results 1 to 16 of 16
Thread: Doh!!! Turn off break Light!!
    Aug 2003
    87 Honda Accord LX-i auto & manual 88' Honda Accord LX auto
    Antioch, CA
    A while back I was driving with some friends and I did an ebrake turn. FOr the next 3-4 days it would randomly come on and go off. Now for the last 2 months the brake light has remained on plus the damn light thats shows when you have a door open has the bottom light that i think says "rear brake light" is also on. I finally have a day off to look at the situation tomorrow. I just wanted to see if anyone has had this problem before. I was thinking that it could be a blown fuse?....but i dunno Thanks for your help
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    Did you check the brake fluid?? Start simple first, then work up to the hard stuff.
    ~Ryan~
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    sounds like you f-ed up the switch that turns on when you pull the handle.
    Nothin' 2 Old Racing
    May 2003
    88 Accord LX 88 Accord LXi
    The "Brake" light could very well be low fluid level. And the "Rear brake light" usually means you have a burnt out rear brake light. Don't forget to check the high mount brake light too.
    '85 lude
    houston
    if you brake fluid is low you most likely need new pads. dont just blindly fill it up. that is a huge pet peeve of mine
    LXi User buds302's Avatar
    Jun 2004
    90 civic hb R.I.P. , 2002 EBP EM2<<figure it out..its not that hard
    new castle pa
    must be nice to do an e-brake turn. i havent been able to do it in 3 years. iv been through 4 3geez in 3 years and when i buy em they wont do it. ive done it all, from changing the shoes to bleeding to adjusting and everything. it just wont do it. this past 3gee i bought wont even hold the car stopped on level ground. but if i have the car jacked up ill step on the brake and it stops no problem. i know im ramblin but my brother will go out, spend 300 bucks on a 3gee and it does it with barely any effort. idunno maybe its me?
    Millington, TN
    Didi you check the rubber bumber?
    I'm not kidding. I was putting in the header and after the rear brake lights were on. Thinking that I had done something I started chasing wires nothing looked wrong.
    So after looking at the brake pedal I noticed that there was hole in front of the plunger switch, then looking on the floor i saw a rubber bumper broke apart this what depresses the brake light switch when you release the brake pedal. Thus if there is not bumper to depress the switch the brake lights will remain on.
    Phil
    86LXItooFAST4me's Avatar
    Austin, Texas
    Quote Originally Posted by buds302
    there should be an adjuster in the eBrake line under the car. I THINK. at least there is one on every other car. you can also do a rear brake job. these two thing can fix your e-brake.
    Car Pics
    vBGarage
    Jun 2004
    new castle pa
    dude i know about the adjuster and ive tried it. ive adjusted it till i cant turn the tire even with a lug wrench. after i set the car down it holds until i start the car, step on the brake and then pull the e-brake and nothing
    Austin, Texas
    what shape are your drums and shoes in?
    Car Pics
    vBGarage
    Jun 2004
    new castle pa
    ive been down this road too many times to count, this past winter my rear brakes locked up. first time thats ever happened. after that i did a brake job(shoes springs clips pins adjuster e-brake cableand drums) still got nuthin
    Austin, Texas
    you made all the adjustment in the shoes and ebrake line? thats wierd, is there any slack in the ebrake line when you have it off?
    Car Pics
    vBGarage
    HostileJava's Avatar
    Northampton, PA
    Quote Originally Posted by nswst8
    Not only that, but cruise control won't engage when you hit the button if that stopper isn't there hitting the sensor.
    Jun 2004
    new castle pa
    ill pull the e brake and itll get real tight after 4 or 5 clicks but the car wont stop rolling
    Austin, Texas
    is it hard pulling on the handle? or easy? i bet your e-line is seized up some where or even broken. have you tried soaking the line with PB blaster or WD40?
    Car Pics
    vBGarage
    Jun 2004
    new castle pa
    now that you mentioned it. i blew a tire about the same time i changed everything (about 3 days)and the tire got all wrapped up in the wheel well. when i changed it i noticed the line looked a little funny but didnt care because the e-brake didnt work anyway.
  1. Break Lamp Light?
    By Hashims in forum Classic Honda Community Chat
    Last Post: 12-24-2008, 03:04 PM
  2. help! brake light won't turn off
    By honda in forum 3geez Accords
    Last Post: 05-23-2007, 05:30 PM
  3. [B]Removing That Dumbass break light in my rear view window.[/B]
    By Trick87Accord in forum Interior & Exterior Care
    Last Post: 03-18-2005, 04:39 PM
  4. Brake light won't turn off.... help!!
    By Hash_man_Se_i in forum 3geez Accords
    Last Post: 01-26-2004, 01:52 AM
  5. the little break light won't turn off
    By meohmy01 in forum 3geez Accords
    Last Post: 03-26-2003, 05:44 PM
