Results 1 to 7 of 7
Thread: Problems with new alarm
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    I just bought a bulldog alarm for cheap and it only hooks up to the battery, so anyways i was testing it, and i connected the wire to the battery and the instructions say if its hooked up correctly it chirps 3 times, well i heard no chirps, and i pressed the arm button, and nothing! the instructions also said something like Warning: DRill all 3 screws to metal material (like firewall) but i didnt mount it yet i just tested it without mounting it and it is grounded to a screw on itself, so is the problem the alarm itself being defective, or do i need to mount it first to act as a "ground" for it to work, even though it is already grounded? plz help
    Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
    SEi User MattsAccord's Avatar
    Feb 2003
    1986 Honda Accord LX
    Southern Oregon, Medford
    I sure it needs a ground to work maybe you should hook it up like it says so it grounded and see if it works.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    all it is is screwing 3 screws threw 3 holes on a mounting plate attached to the siren to mount it, i dont think it will make a diff but put 3 holes in my engine bay.
    So Cal, Orange Co.
    maybe you blew a fuse or somthing on the alarm? im confused, did you not ground it?
    Kevin
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    i dont know if mounting it is technically "Grounding" It but if that is the case and i did blow a fuse by not grounding it, im gonna mount it tommorow and see what happens.
    LX User jonrichert's Avatar
    Aug 2003
    1987 Accord EF Extra(rhd) A18A
    Summerland, BC Canada
    sounds like one of those cheapo alarms that goes off when there's draw on the battery(interior light coming on when the door is busted open etc) if so it relies solely on the ground as a reference point.
    if it has to be mounted to metal, then theres no question thats how it is grounded.
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    ok thanks, i screwed it on and mounted it and it works now! thanks.
  1. Best car alarm out there?
    By FyreDaug in forum Interior & Exterior Care
    Last Post: 10-14-2005, 07:29 AM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. alarm ?'s
    By accordlxi2.0 in forum Interior & Exterior Care
    Last Post: 12-30-2004, 05:30 PM
  4. problems after problems, peep this shit
    By mugenprelude86 in forum 3geez Accords
    Last Post: 08-06-2003, 11:31 AM
  5. Alarm ?????
    By GreenMachine in forum Interior & Exterior Care
    Last Post: 10-08-2002, 05:47 PM
