Results 1 to 5 of 5
Thread: loose steering wheel
    1987/Honda/Accord LX-i
    Los Angeles, CA
    loose steering
    the times i get my car aligned, it doesnt last very long. after alignment, a month later my steering begins to loosen up, and drifts to the left and sometimes to the right.
    is this normal? i would assume alignments would last a bit longer than a month.
    btw i dont drive on a lot of bumpy roads.
    87' Honda Accord LX-i hatch (daily driven)
    00' Acura GSR (track driven)
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Check to make sure that your tie rod jam nuts are tight. Make sure your tie rod ends are in good condition. Check for any suspension looseness (rubber bushings, loose balljoints). If all of this checks out fine, start looking at the inner tie rods and the rack itself. My $.02
    3axap.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Your rack and pinion could be on its' last leg. Could also be your brake calipers not working properly. Check your tie rod ends by pulling back and forth on the tire. (horizonitally) Look at all your suspension components good and look for play.
    Los Angeles, CA
    thanks guys i will check it out later today.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    If it's tight after a front end alignment, the mechanic is most likely tightening the yoke plug nut on the rack and pinion to take the play out of the steering. The need to do this usually means your rack and pinion gears are shot. You would need to replace the rack and pinion gear to fix this. By all means check all your suspension components as well.
  1. Left front wheel axle nut found loose
    By Buzo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2011, 07:34 PM
  2. Loose/stiff steering
    By Ayeobe in forum Classic Honda Community Chat
    Last Post: 08-21-2010, 09:13 AM
  3. cant get my power steering bolt loose
    By Tref_LXI in forum 3geez Accords
    Last Post: 07-11-2003, 03:46 PM
  4. Loose Steering!!!!!
    By 89accordlxi in forum 3geez Accords
    Last Post: 03-03-2003, 05:47 PM
  5. steering feels loose?
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-30-2002, 08:37 PM
