Results 1 to 19 of 19
Thread: have to turn right t go straight
    1987 ACCORD LX
    ONTARIO CANADA
    ok my steering is fuckt up i have to pull right to go sraight i had a friend do an ilingment well the alingment is goot just the weel has to be turnd right to go straight can anyone tell me how can i fix this without touching the alingment
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    maybe you have crazy tire wear on one tire... so the car puls more on one side... I dunno, I'm not a suspension person.
    k-roy's Avatar
    87 LX
    you probably just need to realign the wheel if the suspension checked out ok.
    On the center of the steering wheel pop off the H emblem and remove the 19mm nut. Then you can pull off the wheel and re center it.
    shepherd79's Avatar
    Falling Waters, WV USA
    check the tire pressure if the car pulls to the right or left.
    A20A1's Avatar
    Sep 2001
    Good one Alex... I guess I was stabbing itn the right direction.
    k-roy's Avatar
    87 LX
    oh crap, I just remembered that it could also be the brake caliper starting to seize
    1987 ACCORD LX
    ONTARIO CANADA
    well the ilingment is good well it wont get any better then it is 0.36 on both sides the toe and it wont get any better its not the brake cause i had them off like last week when i was swaping tranys i just took the weeal of my old accord took all the plastick off of it and put her on and senterd it ,it seems to be ok but i still have to fuck with the car to get her to the sweet point still gota adjust the throtel cable its to lose no pedle response and i will try dumping all the vac lines tomorow or most of them
    LX User TheSummoner101's Avatar
    Aug 2004
    89 Accord LX (R.I.P.)
    Bay Area, Cali
    my car has a similar problem, but im not bothered with it, since it only happens on some freeways....
    when im driving it at 70+ on some highways the car starts to pull to left AND right and the ppl behind me think im drunk or something :P but most of the time its fine
    10/Honda/Ridgeline
    NJ
    a) so ur saying that if ur car is going straight the steering wheel looks crooked?
    or are
    b) you saying that ur car pulls to one side?
    If its
    a) your steering wheel was probably not centered. to correct this, take ur car to an empty parking lot and drive straight, irrespective of the steering wheel. then without turning stop the car and remove the steering wheel (no unplugging of wires is needed) and then just put in back straight. It has splines in it for guide.
    b) your alignment is still not right. it will show up on the printout and on the screen if the numbers are not right. If they are right then they will not do anything crazy.
    86 Honda Accord Lx
    Tracy, Ca
    a bent frame can cause the car to pull to one side.
    low tire pressure, uneven tire wear, different tire sizes, different tires brands can cause this as well, a brake caliper not opening up far enough, worn struts or bushings. hope this helps...
    1987 ACCORD LX
    ONTARIO CANADA
    well my alingment wont get better then 0.36 wich is like no bad at all but i senterd the steerin wheal and and its good so i dont care
    1987 ACCORD LX
    ONTARIO CANADA
    lso my steering is loose like lots of play before the car turns left and right how do i tighten then up
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    The alignment was not done properly. All the adjustment for toe in was most likely taken on one side. This can cause your steering wheel to be off center after the alingment was done. Take it to a professional to have the alingment done properly. Be sure to tell them about the steering wheel problem.
    10/Honda/Ridgeline
    NJ
    Shurik. This is what you do. move the carpet near the bottom of the steering wheel and remove the black plastic cover. then u will see the steering column with spines mated to the reciever in the rack. get a 10mm socket or a wrench to it and tighten that bolt. If its loose, it will cause slack in the steering wheel. I had mind like that would make the car wabble in turns cause u have to overcorrect it, it turned out to be that loose bolt. Tightened it and its good now. Also, if the alignment is not right then have them fix it.
    Lets say your driver side front is like -0.35 deg and ur right side is a perfect '0', i would say have your right side match the left side. as in, ask them to set the right side to -0.36 camber too. this is only because u dont want the car to pull to one side, or have them over correct it by adjusting the toe and caster. A lot of alignment shops dont know how to do our caster which really stinks.
    1987 ACCORD LX
    ONTARIO CANADA
    well the problem is i hit a curb doing 80 some african goat joky cut me off
    i was in the side lane he was in the second lane and all of a suden he tryde turning into a side street i slamd my brakes he herd the tier screech and stopt infornt of me sidewayse all i could do is hop the curb if i dint curb my car i would have probly killd his his goat fucking friend in the pasenger seat and the dirty cock sucker ran of like crazy ran off i couldent catch up to him and go figure two nigirean cocksuckers in a toyota camry thats worht les then my rim that i killed and thier car wasent playted
    i have nothing against black ppl but i hate nigers
    10/Honda/Ridgeline
    NJ
    whoa, shurik, i understand your fury, but that language might get u into trouble dude.
    1987 ACCORD LX
    ONTARIO CANADA
    LIKE I side it i am ok with black ppl i just dont like ppl that are pricks
    LXi User Bryan's Avatar
    Jan 2004
    88 Accord DX Coupe 43k miles. Turboed 92 civic hatchback.
    Eau Claire, Wisconsin
    Woah man don't play the race card here. That doesn't score good points.
    88 Accord DX. Custom Mercedes Benz Grey Paint. 16" RS Limited Rival gunmetal rims. Wrapped in Dunlop 205/45/16. MSD Ignition Box 6A. MSD Ignition Coil. NGK Wires. Custom intake w/civic air intake box.2.25 inch exhaust piping. Fireball muffer. Grounding kit.
    Aug 2004
    Bay Area, Cali
    Quote Originally Posted by SHURIK
    90% of the people are brain washed in today's world. those "pricks" you refer to weren't born like that, the media, people, and parents had a lot in raising them, and when some1 dont think like you, or act like you, and is raised differently doesn't mean they are a "prick"
    if your gonna hate people for their actions, thats fine, but dont judge some1 without knowing, and dont steriotype races man
    anyways, since the problem is taken care of, can a mod lock this topic up thanx
  1. straight pipe
    By PeterNtheWolf in forum Performance
    Last Post: 12-02-2010, 08:16 AM
  2. straight pipe
    By jamesh23 in forum Performance
    Last Post: 01-17-2009, 10:48 AM
  3. Straight Pipe!
    By Kaotic1 in forum Performance
    Last Post: 10-30-2008, 08:04 PM
  4. I need a straight answer!
    By James in forum Performance
    Last Post: 09-22-2002, 08:59 PM
  5. straight pipe?
    By Mantis88LX in forum Performance
    Last Post: 07-10-2002, 01:07 PM
