yes, but a hot intake manifold can heat the air up, too... i'm just all for keeping the engine bay as cool as possible... that's the big reason i'd coat the inside, too... then rust as a second reason
if u want to spend the time, very sloppy welding, the welds on the flange to the exhuast head ports, need filing to make it even, u will have to match the exhuast ports with the flange gasket by using a grinding stone................the diameter of the secondary ports are 1 3/4 "............the pipe attaching the cat is 2"....the diameter of the stock header pipe is around 1 7/8"...I don't know, if this pacesetter header is any better than the stock exhaust manifold......anyone dyno ur accord before & after the pacesetter header ??? ??
Consider this the official Pacesetter thread.Originally Posted by FIRST POST IN THREAD
