Page 20 of 20 FirstFirst ... 101617181920
Results 476 to 478 of 478
Thread: Pacesetter : Intake , Short Shifter , Header , Cat Back Exhaust , High Flow Cat
  1. #476
    Vanilla Sky's Avatar
    1999 Penalty Box
    yes, but a hot intake manifold can heat the air up, too... i'm just all for keeping the engine bay as cool as possible... that's the big reason i'd coat the inside, too... then rust as a second reason
  2. #477
    is it better than stock, anyone done a dyno, to prove it??
    if u want to spend the time, very sloppy welding, the welds on the flange to the exhuast head ports, need filing to make it even, u will have to match the exhuast ports with the flange gasket by using a grinding stone................the diameter of the secondary ports are 1 3/4 "............the pipe attaching the cat is 2"....the diameter of the stock header pipe is around 1 7/8"...I don't know, if this pacesetter header is any better than the stock exhaust manifold......anyone dyno ur accord before & after the pacesetter header ??? ??
  3. #478
    Quote Originally Posted by FIRST POST IN THREAD
    What Is Pacesetter , Is It Any Good ?
    Read this thread for member feedback on Pacesetter products ... any questions about pacesetter should be made in this thread.
    Where is Pacesetter Located ?
    Online at : PACESETTER.COM
    PaceSetter Performance Products
    P.O. Box 56397
    Phoenix, AZ 85079-6397
    Where do I buy Pacesetter Products ?
    What Pacesetter Products Are Available For The 86 - 89 Accord ?
    - Short Shifter
    -- 1986-89 / Accord / Shifter Part# 01-0210
    -- 1986-89 / Accord / Shifter Bushing Part# 01-9100
    - Air Intake
    -- For Accord Intake Use: 1990-93 / Integra / Part# 16-1001
    - Cat-Back Exhaust System
    -- 1986-89 / Accord / Cat-Back Exhaust Part# 88-1416
    - 4-2-1 Header ( SE-I , LX-I , DX , LX )
    -- 1986-89 / Accord / Uncoated Header Part# 70-1250
    -- 1986-89 / Accord / Armor Coated Header Part# 72C1250
    - High Flow Catalytic Convertor
    -- 1986-89 / Accord / High-Flow Cat Part# 80-1600
    How Do I Install My Pacesetter Product?
    - How To , Install Header
    - Run a search if you are uncertain how to install other products.
    Consider this the official Pacesetter thread.
  1. Pacesetter Adjustable Short Shifter
    By 88LXi68 in forum For Sale
    Last Post: 07-27-2010, 09:16 AM
  2. Pacesetter Header-Back Exhaust??
    By Soopitup in forum Performance
    Last Post: 04-21-2008, 07:51 AM
  3. Exhaust , Header , & Short Shifter
    By 89hondaSOHC in forum Performance
    Last Post: 08-05-2007, 10:05 AM
  4. Just bought my pacesetter short shifter
    By Trick87Accord in forum Performance
    Last Post: 04-07-2005, 04:45 PM
  5. F/S Pacesetter short shifter
    By 88turboaccord in forum Trading Post
    Last Post: 08-20-2003, 08:41 AM
